bernbomb914
Aug 25 2004, 12:54 PM
finally got to drive the car after way too long. new engine, 2270, new seats, new synchros, new wheels, ATS and tires,Nittos, but somewere I lost 4th and 5th gear put in a rennshift shifter also. so what happened? It shift into those gears but it is like I am in nuteral.
Bernie
brant
Aug 25 2004, 12:59 PM
I'm guessing side to side adjustment in your shift linkage...
its underneath the shifter, yours is not allowing the shifter plane to adjust over far enough...
I think there is a tech article somewhere...
brant
Cap'n Krusty
Aug 25 2004, 01:02 PM
Might want to check the conical linkage bolts under the car.................................. The Cap'n
DonTraver
Aug 25 2004, 01:03 PM
That happened to me. Check that all the set screws on the shift linkage joints are tight (shift knukle at firewall and the at the transmission end of the linkage. Mine backed out about 1 turn, lost 4th & 5th. I locktited them back in with locktite blue. No problems since then.
Aaron Cox
Aug 25 2004, 01:07 PM
haynes has a procedure that describes this....
acces hole in center tunnel, rotate the tunnel shift rod and retightten the screw. makes it all better
bernbomb914
Aug 25 2004, 01:48 PM
Thanks for all the information. That is why this forum rocks.
Bernie
Joe Bob
Aug 25 2004, 03:12 PM
Sounds like ya slipped a spline...but we already knew that...
