UPDATE: Shifter cone screw stripped....., No Luck! |
billh1963 |
Jan 8 2012, 06:22 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Started removing the transmission on the white '76 today and got stymied by a stripped cone screw. The front one was fine...but the screw at the rear of the car looked bad before I even started.
My search has yielded several options: 1. Use an easy out 2. Find the next size up allen head or torx bit and hammer it in. I tried that...didn't work 3. Use JB Weld and "weld in" an allen head or torx bit 4. MIG weld something on the screw (not an option..I don't have a welder) Based on the latest and greatest minds, what's the best option these days? (IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1326068525.1.jpg) |
sean_v8_914 |
Jan 8 2012, 06:26 PM
cheap home depot extractor will do the trick. or harbor freight. heat it up. a butane torch for 3 min (one song on radio) or till it sizzles when ya spit on it.
billh1963 |
Jan 8 2012, 06:38 PM
scotty b |
Jan 8 2012, 06:41 PM
Knock the bushing out of the way first. Plastic and heat dont go well together
charliew |
Jan 8 2012, 06:42 PM
yep, all around the screw. as it's cooling maybe shoot a little pb blaster on the screw threads or around the screw.
EdwardBlume |
Jan 8 2012, 06:45 PM
Drill it out get a new cone screw.
billh1963 |
Jan 8 2012, 06:52 PM
The bushing is looking pretty rough....
(IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1326070348.1.jpg) |
jimkelly |
Jan 8 2012, 07:30 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
if you bugger up that piece - i have one for you free east coaster : )
billh1963 |
Jan 8 2012, 07:55 PM
if you bugger up that piece - i have one for you free east coaster : ) Thanks, Jim. I hope it doesn't come to that! If I screw it up I'll let you know.... (IMG:style_emoticons/default/smile.gif) |
timofly |
Jan 8 2012, 08:12 PM
Member Group: Members Posts: 164 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
Until you have stripped this screw, you aren't really a 914 mech. The extractor works just fine, but be careful with the torch on oily/greasy parts. Good idea to have a fire extinguisher handy. Generally a good idea around the shop anyway.
sixaddict |
Jan 8 2012, 08:30 PM
Senior Member Group: Members Posts: 803 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Until you have stripped this screw, you aren't really a 914 mech. The extractor works just fine, but be careful with the torch on oily/greasy parts. Good idea to have a fire extinguisher handy. Generally a good idea around the shop anyway. did this with extract not easy out and worked fine with no heat |
SCV |
Jan 8 2012, 09:42 PM
Aircooled Enthusiast Group: Members Posts: 92 Joined: 1-August 09 From: Austin, Texas Member No.: 10,630 Region Association: None |
+1 for heat and an extractor to remove stripped cone screws. This process worked flawlessly when new shift rod bushings were installed in Yellow last year. The PO used Loctite to install the cone screws, and the rest is history.
VOX |
Jan 9 2012, 02:41 AM
Member Group: Members Posts: 129 Joined: 6-February 09 From: rosemead, ca Member No.: 10,027 Region Association: None |
i stripped one before. i used a drill bit, just a little bigger, drilled it, then hammered in an allen wrench.
Stonepilot |
Jan 9 2012, 06:33 AM
Newbie Group: Members Posts: 20 Joined: 6-December 11 From: Pensacola, Florida Member No.: 13,863 Region Association: South East States |
use the extractor no heat required
Bartlett 914 |
Jan 9 2012, 07:30 AM
billh1963 |
Jan 9 2012, 08:09 AM
Going out at lunch to Lowes (No HD here). Picking up a bolt extractor set and a MAP kit
IronHillRestorations |
Jan 9 2012, 09:40 AM
Definitely heat it! If you have a high power soldering iron that may be enough to help.
1. Clean off all dirt and grease 2. Spray liberally with PB blaster or Kroil, let soak for as long as possible, re-apply, tap with hammer to help oil penetrate 3. Apply heat |
Dr Evil |
Jan 9 2012, 10:08 AM
HEAT! Figure it this way: If it needed heat and you did not heat it, then you strip the extractor and it sucks worse. If you heat it and it didnt need it, no biggie.
VaccaRabite |
Jan 9 2012, 10:16 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
And you are going to want to replace the plastic bushing anyway, so no biggie if it melts. Cheap and very easy to replace.
Zach |
billh1963 |
Jan 9 2012, 10:21 AM
I figured "while I was in there" I would replace all the bushings anyway. Best source? I see pelican has a package for all the bushings from the shifter back.
Lo-Fi Version | Time is now: 18th May 2024 - 12:22 PM |
