WTB Stainless Fuel Lines, Stainless Fuel Lines |
RobertD |
Jan 10 2012, 08:28 AM
RobertD Group: Members Posts: 21 Joined: 23-September 03 From: Independence, KY Member No.: 1,188 Region Association: None |
Ok guys before I buy a set of stainless fuel lines, does anyone have a set that they purchased and are now not going to use? Anyone made their own using aluminum tubing or braided stainess?
Thanks RobertD |
0396 |
Jan 10 2012, 08:58 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I'm sure there are some out there.., I even have a set but plan on using them.. back to my post, I'm not sure what your time is, but if it were me , I would just by a set from Chris Foley here and be done with it.
zymurgist |
Jan 10 2012, 09:12 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I made a set out of mild steel. That was just before Chris started selling his stainless lines. If I had to do it again, I would buy his product.
strawman |
Jan 10 2012, 01:44 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
(IMG:style_emoticons/default/agree.gif) the Foley ones fit great!
pilothyer |
Jan 10 2012, 03:59 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I know the material is easy to bend to the shape you will need, but I would "think twice" before making these out of aluminum tubing.
JeffBowlsby |
Jan 10 2012, 05:10 PM
914 Wiring Harnesses Group: Members Posts: 8,503 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Another solution is to make them from the same material the factory did. Nylon 6 tubing, available from McMaster-Carr and other places, its not expensive. Nylon 6 is heat formable. It will embrittle and discolor over a very long time period due to moisture absorption just like the factory originals, but should be good for about another 30 years or so before needing replacement.
Lo-Fi Version | Time is now: 14th May 2024 - 06:34 AM |
