partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Someone mentioned about making a radiator utilizing copper fin tubing??
http://www.fintube.com/plate-finned-tubing.html I wonder if this would be practical? I'm getting tired of aluminum radiators popping their screws all the time. Too many ifs, could be's and maybe's about whether to try and send it in and fix it, if it even can be, or just junk it and find another route. I would think copper would be easier to solder if needed, than fixing the aluminum. The guy behind the counter thought that if you could give them the information on like, size, how much the water pump, pumps, etc. they could figure out how big a person would need it to be. Or is there a normal copper radiator that would work better? |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
What'cha trying to cool and by how much?
If you're popping screws then is it a pressure thing or a vibration thing? Both are soft metals, more info. (IMG:style_emoticons/default/beerchug.gif) |
ruby914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None ![]() |
I considered using something like that in my long tubes to heat the passenger compartment.
partwerks |
My electrician had an idea about making a radiator for the subie conversion since my aluminum radiator is seeping again, but I think I will send it in and hopefully can be repaired? I would think copper would be easier to fix than aluminum if a person was to try and make something?
He also mentioned using the coil out of a A/C unit? |
Lo-Fi Version | Time is now: 1st July 2025 - 01:36 AM |
