oil pump for 2056 |
oil pump for 2056 |
jmargush |
Jan 14 2012, 07:33 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am in the beginnning stages of a 2056 build.
I am curiuos on what the reccomendations are for the oil pump? Is a stock type 1 pump the way to go or are there performance aftermarket pumps that are the better way to go? Sources? |
Mark Henry |
Jan 14 2012, 09:50 AM
26mm or 30mm type 1 schadeck pump, I wouldn't use any of the AM pumps, even the schadeck doesn't have the QC they used to have.
I would just get one of Jake's pumps (type 4 store) as he specs them out and modifies (clearance) them for the type4. Use a steel pump cover. |
Harpo |
Jan 14 2012, 10:01 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have never seen complete pumps on the type 4 website, only some components.
Dave |
Mark Henry |
Jan 14 2012, 10:12 AM
I have never seen complete pumps on the type 4 website, only some components. Dave It is a complete type one pump as it would come from the dealer, all that is missing is the cover. You would use a stock type1 cover if you plan to use the stock filter or a full flow cover if you plan on a remote filter adapter. Be aware that if you go full flow you need to modify the one engine mount. |
Jake Raby |
Jan 14 2012, 12:01 PM
We haven't sold oil pumps for about 3 years now.. Got fed up with people building engines without checking clearances and ending up with low oil pressure... Then getting the finger pointed toward the oil pump when it wasn't at fault.
jmargush |
Jan 14 2012, 02:37 PM
Jake,
Do you have reccomendations on what/where to buy one from? |
Speedster Mike |
Jan 14 2012, 03:19 PM
Speedster Mike Group: Members Posts: 39 Joined: 1-March 09 From: Louisville , Ky. Member No.: 10,113 Region Association: Upper MidWest |
Got Mine from Darrin over at DRD RACING HEADS in California...Type 1 set up and modifyed for TYPE IV motor, 30mm. Perfect fit....all is well
Lo-Fi Version | Time is now: 18th May 2024 - 03:05 AM |
