Experience with Electromotive HPX or XDI?, On a 6 |
jmill |
Jan 15 2012, 05:06 PM
I currently have a 2.4T motor without a dizzy. I don't have the funds to go straight to the 2.2S P&C's, large port heads and Solex cams. I'm going to "refresh" the T motor and make this thing a driver while I save up for the raped ape motor. I'm thinking I can go with the HPX or XDI and not have to worry about buying a Bosch dizzy with a T advance curve and then get it recurved when I go with the new engine bits.
Anyone have experience with the HPX or XDI? |
brant |
Jan 15 2012, 07:06 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I currently have a 2.4T motor without a dizzy. I don't have the funds to go straight to the 2.2S P&C's, large port heads and Solex cams. I'm going to "refresh" the T motor and make this thing a driver while I save up for the raped ape motor. I'm thinking I can go with the HPX or XDI and not have to worry about buying a Bosch dizzy with a T advance curve and then get it recurved when I go with the new engine bits. Anyone have experience with the HPX or XDI? I've only done it on a -4 but correct you can tune any "advance curve" you want into the electromotive. they are actually available used at really really good prices you can practically buy a used unit for the same price as a good used dizzy. (maybe a tiny bit more) but then you can use the same electromotive on any future engine also. brant |
ellisor3 |
Jan 15 2012, 07:20 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
Here is a good source for information. I have the Electromotive Tec-GT and I discussed options with Richard Clewett. Very knowledable on Porsche.
http://www.clewett.com/index.php?main_page=index&cPath=1 |
jmmotorsports |
Jan 15 2012, 07:56 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
I ran an HPV-1 on my V8 for several years without any issues. Very cheap used . Quite a few 911 guys on Pelican run Electromotive ignitions,you can find a lot of info there. I would go this way again before spending any money on a dizzy and coil ignition.
Jerry . |
Matt Romanowski |
Jan 16 2012, 11:11 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
There are a lot better systems that Electromotive. They still use a RS232 or serial cable (no USB) and are stuck on the wasted spark idea. You're much better off going with Motec ($$$) ot Haltech (very reasonable).
SLITS |
Jan 16 2012, 11:33 AM
If you want a unit ... I have an extra HPX and HPV-3B**
HPX ... dials on unit, no computer required. Ignition only. **HPV-3B ... requires software & I don't have the correct one. Ignition only ... no injectore drivers. |
GeorgeRud |
Jan 16 2012, 08:06 PM
I've had the Electromotive system on my conversion for many years, and it's worked fine. You do need to have the battery charged for it to work properly, and it's an absolute pain in the a.. if you have to change the sensor with the engine in the car (ask how I know).
Rich Clewitt is a great source of parts for the Electromotive and has done a nice job setting this up for the 911 type engine. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:12 AM |
