Side Shifter Tranny Leak, Drive shaft seals |
bcheney |
Jan 16 2012, 08:33 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
I finally got the engine and tranny installed into my 6 conversion. I decided to install the shift rod today and ran into a problem. After securing everything with the shifter and moving it in and out of gear I later noticed a leak. I was so focused on other bits that I didnt see the leak until I went back under the car a few hours later. The tranny ran without issue many years ago...(15 plus years). I did not decide to open up the tranny prior to installing it into my conversion. Probably a mistake in hindsight. I remember changing the oil in about 1000 miles before the car got parked. Anyways...here is a picture of what happened today. I am hoping this can be addressed without lowering the package out of the car now that I finally got in there. Could it be a bad driveshaft seal? If so can it be changed where it sits...Could it have generated this leak as a result of changing gears a few times today after its sat for all these years? I installed the engine and tranny about a week ago and the leak only became visible today...so I'm thinking this isn't a coincidence. Dr Evil...are you out there?
flash914 |
Jan 16 2012, 08:52 PM
Member Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California |
With the axles out it is a very good time to do it. The haynes manual shows how to do it. It could be that when you last cleaned the transmission, water got between the seal and drive hub, rusted and when you turned the hubs it tore the seal?? Input OK??
wingnut86 |
Jan 16 2012, 09:00 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Good news/bad news...
1st read throgh Dr. Evils notes, I think he addresses this. If not, when was the Tranny fluid changed? Did you transition from one gear oil type to another? If you changed up to Swepco then you have probably got the typical high viscosity to lower viscosity issue associated. In many cases, no pun intended, your case will begin weeping at all the seals. Especially if the previous gear oil sat for 15 years and thickened. Run it while it's warm for a while and allow the oil to heat up. Then replace/change it out with some less expensive/same viscosity oil. Stay with Dino or Synthetic, but don't mix them up. Warm it up again and let the new oil circulate. Dry the case surface with some pure sawdust or pure clay cat litter so you can see the drainage better. Sit overnight, check after warming up again. Sometimes the diff seals will get some pliability back. If she's still leaking, pull the tranny after you drain her and order all the diff seals, diff bearings, cone seals, etc... this is the downside... |
wingnut86 |
Jan 16 2012, 09:10 PM
Once you establish that the older seals are dried and deformed and leak, it's much better to replace all the seals with the tranny out and not chance a $1000 rebuild by letting things run adequitly. Just breath deep, get some new seals and fresh swepco or a similar grade oil to fill it up next time.
You just saved yourself $1000 and spent less than $200 if everything goes back right and breaks in appropriately. (IMG:style_emoticons/default/smile.gif) Good Luck |
bcheney |
Jan 16 2012, 09:11 PM
Thanks for the responses so far. Let me clarify...I haven't changed the oil since it was last changed over 15 years ago. The car sat all this time and the tranny was out of it sitting on the garage floor.
wingnut86 |
Jan 16 2012, 09:25 PM
Run clean oil through her and dissassemble her for maintenance.
$100 in seals and orings. Do it to it... Or bring it to me and I'll use Dr.'s Evil's bible and restore her. I can arrange a tranny swap with your's if preferred. Stainless hardware on the return trip on the new one. Any change in the basic gearing would need to be swapped over as I stock no LS Diffs or race paired gearing. Let me know, Dave |
Dr Evil |
Jan 17 2012, 05:36 AM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Thats an easy one (IMG:style_emoticons/default/smile.gif)
Replace the seals with the box in place. Since the axles are not in the way, you have an easy go of it. The CV flanges are only held on by a single 19mm bolt that is not supposed to be tq to high. Place a drift in one of the bolt holes so that it rests on a rib and stops the flange from turning. Remove the 19mm bolt. Pull the flange out. Use a hooked seal puller to pull the seal out. Lube new seal with vasoline or the like on the out side. Pound it in flush with the ridge on the seal bore. Install flanges in reverse. Enjoy (IMG:style_emoticons/default/smile.gif) I likely have some of these seals out of kits if you need them. A word of caution, you may need to replace the front seal as well which will require the tranz to be dropped, but changing it is not that hard. You dont need a rebuild unless the box is shifting poorly (which you may discover once all is installed (IMG:style_emoticons/default/sad.gif) ). |
bcheney |
Jan 17 2012, 05:51 AM
Thats an easy one (IMG:style_emoticons/default/smile.gif) Replace the seals with the box in place. Since the axles are not in the way, you have an easy go of it. The CV flanges are only held on by a single 19mm bolt that is not supposed to be tq to high. Place a drift in one of the bolt holes so that it rests on a rib and stops the flange from turning. Remove the 19mm bolt. Pull the flange out. Use a hooked seal puller to pull the seal out. Lube new seal with vasoline or the like on the out side. Pound it in flush with the ridge on the seal bore. Install flanges in reverse. Enjoy (IMG:style_emoticons/default/smile.gif) I likely have some of these seals out of kits if you need them. A word of caution, you may need to replace the front seal as well which will require the tranz to be dropped, but changing it is not that hard. You dont need a rebuild unless the box is shifting poorly (which you may discover once all is installed (IMG:style_emoticons/default/sad.gif) ). That is good news. I will order and replace the seals...They're pretty in expensive on Pelican. (I'm sure the seals you have will come in handy when you're doing a rebuild on site with someone). The front seal follows a similiar procedure for r/r? Thanks so much for chiming in (IMG:style_emoticons/default/smile.gif) |
bcheney |
Feb 11 2012, 01:19 PM
Dr Evil, Just want to be sure I am installing the CV flange seal correctly. When you say the seal rides flush with the ridge on the seal bore...does that look like the seal in this pic?
wingnut86 |
Feb 11 2012, 01:41 PM
Um, you've had moisture infiltration as well. That leaking seal or the speado seals can be the culprits.
Dr. Evil is holding a clinic in Virginia in a few that would be real good experience if you can wait. No, it's not considered a carry-on item with the airlines. The good Dr. also has a way to ship it to the event as well. PM him separately for details if interested. |
bcheney |
Feb 11 2012, 01:52 PM
Ok..I replaced the pic posted with a new one that actually shows my tranny and seal. Does it show the seal installed correctly? Just want to make sure I have it resting in there the right way.
Dr Evil |
Feb 11 2012, 04:00 PM
The seal looks like it may be a bit farther in than I recommended, but if it is not interfering with anything, and not far past the little shoulder at the edge of the bore, run it and have fun (IMG:style_emoticons/default/smile.gif)
bcheney |
Feb 14 2012, 07:19 AM
Ok split the engine and tranny to inspect/replace the driveshaft seal. The seal is green in color and is still pliable. It has been in place since the mid eighties...at least...The replacement seals of today appear to be sligthly larger front facing material. The ID is the same. I guess its best to just go ahead and replace even though the original appears to be in good shape? the first photo shows the original seal in place. The second shows the new seal slipped over the shaft. You can see the difference between the two.
Attached thumbnail(s) |
Dr Evil |
Feb 14 2012, 07:51 AM
Old style has a shoulder around the outer dia. It is OLD. Replace it.
bcheney |
Feb 14 2012, 08:15 AM
sean_v8_914 |
Feb 14 2012, 08:37 AM
dont forget to polish the rotating surface that the seal touches. a schotch brite pad works well. polish in a radial motion. when things sit for a long time, these seal surfaces get gunk or oxidation that prevents proper seal. seal installation depth will change where it rubs on the mating part.
since the trans is out i would change all seals. diff cover o ring... |
bcheney |
Feb 14 2012, 09:01 PM
Thanks for the heads up Sean!
bcheney |
Feb 16 2012, 09:31 PM
Old style has a shoulder around the outer dia. It is OLD. Replace it. Man...the driveshaft seal is in one helluva precarious location to remove. As I mentioned before the seal is still very pliable. I am concerned that I'm gonna F-up the surface tryin to get this bad boy out. What tools and method do you use to remove? Sorry for being such a pain in the -ss about this. The CV flange seals were easy to work with...this one is a prick. |
Dr Evil |
Feb 16 2012, 09:38 PM
Seal puller, available at most places.
bcheney |
Feb 16 2012, 10:20 PM
I just read this one seems to get better reviews on Harbour Freight.
Lo-Fi Version | Time is now: 21st May 2024 - 04:09 AM |
