Momo Steering Wheel, hands too close to stalks |
ber914 |
Aug 26 2004, 05:56 AM
Newbie Group: Members Posts: 43 Joined: 8-April 04 From: Sydney, Australia Member No.: 1,908 |
I have fitted a Momo steering wheel with a Momo hub adaptor to my 72 914. My hands are now too close to the stalks on the steering column. Is this a common problem and is there an easy solution other than getting a spacer machined up?
Robert |
machina |
Aug 26 2004, 05:59 AM
I think MOMO makes a spacer to push the wheel back a bit.
Otherwise you may need a wheel with a deep dish like the mod 07. dr Attached image(s) |
Fastalswanson |
Aug 26 2004, 06:13 AM
Newbie Group: Members Posts: 4 Joined: 28-July 04 From: Greenville, TX Member No.: 2,414 |
I put the Momo 1/2" space on mine and it works much better.
If I did it again, I think I would use the 1.0" spacer. GPR sells the spacer kits. |
JWest |
Aug 26 2004, 06:50 AM
QUOTE(Fastalswanson @ Aug 26 2004, 07:13 AM) I put the Momo 1/2" space on mine and it works much better. If I did it again, I think I would use the 1.0" spacer. GPR sells the spacer kits. I concur - get the spacer. |
Aaron Cox |
Aug 26 2004, 11:08 AM
wierd. i have a prototipo...not much dishm and a hub..i dont have any problems..... (IMG:style_emoticons/default/idea.gif)
which hub do you have- the one with the rubber boot or the cast.milled aluminum piece? one apperars to be longer than the other |
fiid |
Aug 26 2004, 01:06 PM
Pelican sells a 1/2" spacer which is what I have on my car. Solved the problem quite nicely.
Fiid. |
seanery |
Aug 26 2004, 01:11 PM
personally, I think steering wheels are for pussies! A real man can drive with a pair of vice grips attached to the column! (IMG:style_emoticons/default/laugh.gif)
fiid |
Aug 26 2004, 01:16 PM
Vice grips are for pussies.
Real men use a ratchet, and flick the direction back an forth depending where they want to go. (IMG:style_emoticons/default/biggrin.gif) |
seanery |
Aug 26 2004, 01:17 PM
HAAA! (IMG:style_emoticons/default/laugh.gif)
Cap'n Krusty |
Aug 26 2004, 01:44 PM
REAL men throttle steer ........................ Didn't you learn ANYTHING from The Dukes of Hazzard, one of the greatest documentarys ever filmed? The Cap'n
lapuwali |
Aug 26 2004, 01:47 PM
Hm. I thought the real lesson from Dukes was that real men didn't steer at all. They just jumped over anything in the way...
Elliot_Cannon |
Aug 26 2004, 02:30 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Hi,
I had the some problem with my wheel. It has a smaller diameter than stock and is closer to the dash. I kept hitting the wiper lever and activating the wipers on a dry windshield. My solution was to cut the damn lever off. It is now much shorter and harder to hit while steering. I filed the end smooth and painted it. I may do the same with my turn signal switch. A little drastic but it works for me. Some people here in So. Cal. disable the wipers till the winter. You know....the "rainy season" LOL Cheers, Elliot |
Lo-Fi Version | Time is now: 21st May 2024 - 05:18 AM |
