ber914
Aug 26 2004, 05:56 AM
I have fitted a Momo steering wheel with a Momo hub adaptor to my 72 914. My hands are now too close to the stalks on the steering column. Is this a common problem and is there an easy solution other than getting a spacer machined up?
Robert
machina
Aug 26 2004, 05:59 AM
I think MOMO makes a spacer to push the wheel back a bit.
Otherwise you may need a wheel with a deep dish like the mod 07.
dr
Fastalswanson
Aug 26 2004, 06:13 AM
I put the Momo 1/2" space on mine and it works much better.
If I did it again, I think I would use the 1.0" spacer.
GPR sells the spacer kits.
JWest
Aug 26 2004, 06:50 AM
QUOTE(Fastalswanson @ Aug 26 2004, 07:13 AM)
I concur - get the spacer.
Aaron Cox
Aug 26 2004, 11:08 AM
wierd. i have a prototipo...not much dishm and a hub..i dont have any problems.....
which hub do you have- the one with the rubber boot or the cast.milled aluminum piece? one apperars to be longer than the other
fiid
Aug 26 2004, 01:06 PM
Pelican sells a 1/2" spacer which is what I have on my car. Solved the problem quite nicely.
Fiid.
seanery
Aug 26 2004, 01:11 PM
personally, I think steering wheels are for pussies! A real man can drive with a pair of vice grips attached to the column!
fiid
Aug 26 2004, 01:16 PM
Vice grips are for pussies.
Real men use a ratchet, and flick the direction back an forth depending where they want to go.
seanery
Aug 26 2004, 01:17 PM
HAAA!
Cap'n Krusty
Aug 26 2004, 01:44 PM
REAL men throttle steer ........................ Didn't you learn ANYTHING from The Dukes of Hazzard, one of the greatest documentarys ever filmed? The Cap'n
lapuwali
Aug 26 2004, 01:47 PM
Hm. I thought the real lesson from Dukes was that real men didn't steer at all. They just jumped over anything in the way...
Elliot_Cannon
Aug 26 2004, 02:30 PM
Hi,
I had the some problem with my wheel. It has a smaller diameter than stock and is closer to the dash. I kept hitting the wiper lever and activating the wipers on a dry windshield. My solution was to cut the damn lever off. It is now much shorter and harder to hit while steering. I filed the end smooth and painted it. I may do the same with my turn signal switch. A little drastic but it works for me. Some people here in So. Cal. disable the wipers till the winter. You know....the "rainy season" LOL
Cheers, Elliot
