Need help refinishing trunk- seam sealer issue |
sixaddict |
Jan 22 2012, 10:15 AM
Senior Member Group: Members Posts: 801 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
So trunk had some water and resultant surface rust under edges....So cut out seam sealer. Ready to repaint and need a solution of how to duplicate look as most was not removed...Asked "expert" and found gun to do it right is $400....that is just not in the cards
Can you tell me of source for the (rough looking) sealer that is used around edges and a way to spray it ...My body guy is good ole boy but low on resource information About two weeks " (IMG:style_emoticons/default/headbang.gif) " and I am ready for this to me done. Any help would be appreciated. Will post pictures when done Thanks Terry (IMG:style_emoticons/default/pray.gif) |
jaxdream |
Jan 22 2012, 10:47 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Since you are going for the look alike , try either rope or brush on sealer on maybe some mock up thing . Use some type of hand roller to dimple , scallop , imprint a surface that resembles the surface of the sprayed sealer . Could be dirt cheap to a little $$ spent . Just an idea as it seems that the seams will be sealed , just want the appearence to be compatable with whats not removed. Good luck on ya search . (IMG:style_emoticons/default/smile.gif)
Jack |
jmmotorsports |
Jan 22 2012, 10:48 AM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
This is what I use. I have had this gun for years and don't remember what it cost but should be less than $ 50.00. Any body shop supply store should have it. Put a regulator on it and you can dial in the pattern you want.
Jerry |
sixaddict |
Jan 22 2012, 01:28 PM
Matt Romanowski |
Jan 22 2012, 01:47 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Rocker shutz is the way to go. You can get the 3m stuff in an aerosol and can mimic the original stuff pretty well. You could probably do it with paintable undercoat too as long as it dried hard. Do a bunch of test peices to get the right look before trying it on your car.
Lo-Fi Version | Time is now: 14th May 2024 - 02:58 PM |
