| gregrobbins |
Aug 27 2004, 01:55 PM
Member: Team NARP ![]() ![]() ![]() Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Just got off the phone with my mechanic who is trying to get the car to pass emissions. He says the MPC Sensor is bad and he is having trouble locating one. I took a quick look at Pelican and their price is $975 or so. Mechanic suggested going to carburation, but I am leaning on keeping the car original if at all possible.
Help! I would appreciate any and all suggestions and ideas. Thanks! (IMG:style_emoticons/default/sad.gif) |
| brant |
Aug 27 2004, 01:59 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,107 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
buy a used one around here that tests good...
(I have a used one, I could sell for a 2.0) or get yours rebuilt. I think rebuilts are $250, but don't quote me on that.... brant |
| mike_the_man |
Aug 27 2004, 02:05 PM
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
I'd stick with the FI, personally. Without changing the cam, you won't get much benefit from switching to carbs. About the MPS, what about is is bad? Does it not hold a vaccuum? Are the coils bad? Or is it just out of adjustment? Depending on whats wrong, there are various ways to fix it. I think SLITS may have a few decent used ones. Geoff Bleyseng also recalibrates them, and he may still have a few good ones. I'm sure they'll chime in. If you could give us more info on whats wrong, it'll be easier to help.
If you haven't read Brad Anders web page yet, take a read. It explains how to test the MPS, and how it works. Brad Anders |
| lapuwali |
Aug 27 2004, 02:19 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
And as being discussed in another thread, if your MPS does turn out to be bad, one alternative is to go with a Megasquirt replacement ECU, which will replace the MPS with a solid state sensor. This may be more DIY than you intend to do, and I'll bet more than your mechanic can handle if he's pushing carbs. Just switching to carbs and doing nothing else will kill your gas mileage (15-20mpg is normal).
| Cap'n Krusty |
Aug 27 2004, 02:27 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I have close to 30 years experience with rebuilt MPS units, from various sources and at various prices. I had a good friend who produced the best ones out there, using a Bosch style test bench, and they were such a hassle he quit doing them in the mid '70s. There have NEVER been any replacement parts available, and no one else uses a bench like he had. Don't waste your money ..................... The Cap'n
| nebreitling |
Aug 27 2004, 02:55 PM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
QUOTE(gregrobbins @ Aug 27 2004, 11:55 AM) Just got off the phone with my mechanic who is trying to get the car to pass emissions. Mechanic suggested going to carburation, if you have a visual test in arizona, you won't be able to pass emissions with carbs at all. |
| JoeSharpOld |
Aug 27 2004, 08:37 PM
Does it seem cold to you ![]() ![]() Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 |
I got one from High performance House for 160.00 with mine for the core. It seem to work fine, but I just got it running last week and with a new engin I wont know how well it works for sometime. I've still not had it above 3K and still tuneing the engin.
Joe |
| Bleyseng |
Aug 28 2004, 01:15 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
First test your mps with a vacuum pump. Pull 15hg on it and see if it holds, shouldn't leak down more than a few lbs in 5 minutes. If it holds its good and your mechanic needs to look elsewhere for the problem. Lots of mechanics don''t know too much about Djet and just play plug and pray with it. Next he might blame the ECU......
Use Brad Anders site to do some testing yourself to narrow the problem down. Geoff |
| tod914 |
Aug 28 2004, 01:18 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
I seen Pelican rents a Djet tester. Has anyone ever tried that to diagnos a problem?? Just curious.
| eeyore |
Aug 28 2004, 09:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
greg:
Your signature indicates a you have 1.7. You could try the MPS from the 1.7on the 2.0 (I mentioned this in another thread as well) tod: I've used the D-Jet tester from PP. What I recall is that it doesn't really test the MPS or FI trigger points, just the FI brain. Unfortunately, it didn't help diagnose my problem of why does dizzy(X) work beautifully, and dizzy(Y) work so poorly? A varied combination of parts between X and Y didn't reveal much either. |
| brant |
Aug 28 2004, 11:16 AM
QUOTE(Cloudbuster @ Aug 28 2004, 08:33 AM) Unfortunately, it didn't help diagnose my problem of why does dizzy(X) work beautifully, and dizzy(Y) work so poorly? A varied combination of parts between X and Y didn't reveal much either. Cloudbuster, I have the same problem with dizzy X working but after the car warms up Dizzy Y does not work... I finally am of the mind that is because my dizzy Y is not advancing correctly (somehow) the funny thing is that my dizzy X is rusty and corroded, and my dizzy Y is spotless, shiny, and looks new....... brant |
Lo-Fi Version | Time is now: 9th December 2025 - 05:44 PM |
