Speedo Angle Drive, finally got those damned things out |
76-914 |
Jan 22 2012, 06:56 PM
McMark |
Jan 22 2012, 07:15 PM
Pull it out. There should be nothing but aluminum.
windforfun |
Jan 22 2012, 08:44 PM
Senior Member Group: Members Posts: 1,785 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
76-914 |
Jan 23 2012, 10:15 AM
Scott S |
Jan 23 2012, 10:21 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Pull it out. There should be nothing but aluminum. Any suggestions? It seems solid when I tap on it. I just did this last month. I also thought it was part of the casing - it's not. I was a bi+ch to get out. I finally deformed the inner edge enough to get it to pull free from the aluminum. I did have to free it all the way around. I thought that once one area came away from the aluminum, the thing would come out easily. It was like it was litterally bonded all the way around. Not fun - and I was (and still am) a bit concerned I may have scratched the inner bore. We'll see..... Mine was also blue aaround the outside like yours - I am guessing in my case the PO permatexed the thing in. Good Luck (IMG:style_emoticons/default/beerchug.gif) |
Dr Evil |
Jan 23 2012, 10:23 AM
It is there to make sure oil does not migrate down the shaft. It is a PITA to change :/
jflash914 |
Jan 23 2012, 10:30 AM
Member Group: Members Posts: 80 Joined: 24-February 05 From: binghamton,ny Member No.: 3,652 |
Doc,
Is there even an O ring seal you can buy or do you have to improvise? BTW it was fun meeting you yesterday. It was a long trip for one day. Jack |
Dr Evil |
Jan 23 2012, 10:39 AM
There is a new seal. I dont have the part # handy. I may have one available in my stash.
Great meeting you and your Pops yesterday. I wish we could have BSed all afternoon, but I know you had a long 6hr drive back home. (IMG:style_emoticons/default/smile.gif) |
Elliot Cannon |
Jan 23 2012, 11:13 AM
When I dug out the old seal there was rubber both above and below this ring. Was it part of the old seal? Or, should be removed. If so how? It"s tighter than socks on a rooster, as it is now. So which gets used the most? The digital calipers or the ball peen hammer? (IMG:style_emoticons/default/laugh.gif) |
76-914 |
Jan 23 2012, 11:42 AM
Doc, Is there even an O ring seal you can buy or do you have to improvise? BTW it was fun meeting you yesterday. It was a long trip for one day. Jack Call Jonathen @ GPR. He's got the seal and the oring or save ygourself the trouble and order one of McMarks units ready for installation. |
Drums66 |
Jan 23 2012, 05:09 PM
When I dug out the old seal there was rubber both above and below this ring. Was it part of the old seal? Or, should be removed. If so how? It"s tighter than socks on a rooster, as it is now. ......Grab it by the spurs, & pull it out(it should come out) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
Jan 23 2012, 05:45 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Pull it out. There should be nothing but aluminum. (IMG:style_emoticons/default/agree.gif) Pull it all out. I'm pretty sure that's just part of the old seal that came apart when you tried to remove it. No additional o-ring there, just the new seal itself. I have a thread somewhere with part-numbers ... (IMG:style_emoticons/default/chowtime.gif) |
76-914 |
Jan 24 2012, 07:21 PM
Here's the thread that Andy mentioned. http://www.914world.com/bbs2/index.php?showtopic=50540
Anyway, check this out. I finally got those little bastards out. I used a nail set and hammer. The divots give it a bearing look. But it's true. It is a war and if I did not have a couple of extra ones drives I would never had been so rough on them. (IMG:style_emoticons/default/biggrin.gif) You can see that the one on the right still has some of the blue plastic around it. You can see where the plastic is separating from the metal ring. Which BTW, is definatly part of the seal. |
McMark |
Jan 24 2012, 10:46 PM
Yeah, I made a special tool to take them out. (IMG:style_emoticons/default/wink.gif)
Bob L. |
Jan 25 2012, 12:21 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Hi there,
I have just realized that my angle drive is bad. If I push the rotating parts inward in the angle drive the gears will connect and turn. Will replacing the seal help this, or only the leak? Thanks. |
McMark |
Jan 25 2012, 06:29 PM
The angle drive is a separate piece that is non-repairable.
If you have removed the angle drive from the speedo drive, and there is still a disconnect, it's toast. They are available new. I have a few good used ones. |
Bob L. |
Jan 26 2012, 09:41 AM
O.K. It's toast. How much for one of your used ones? (McMark) or should I just go to AA? My speedo cable looks kinked near where it connects to the angle drive. Should I change it as long as I'm at it. Or, as long as it works...leave it.
Thanks. Hijack over! |
76-914 |
Jan 26 2012, 09:56 AM
O.K. It's toast. How much for one of your used ones? (McMark) or should I just go to AA? My speedo cable looks kinked near where it connects to the angle drive. Should I change it as long as I'm at it. Or, as long as it works...leave it. Thanks. Hijack over! Hi jack allowed. Your from my hometown (IMG:style_emoticons/default/biggrin.gif) . I would by one of McMarks. He has modified them to accept an additional O ring. Should reduce axial play and last longer. |
Bob L. |
Jan 26 2012, 09:56 PM
QUOTE Hi jack allowed. Your from my hometown (IMG:style_emoticons/default/biggrin.gif) . I would by one of McMarks. He has modified them to accept an additional O ring. Should reduce axial play and last longer. Appreciate it! O.K. I'll bite. Does it come w/ the extra O ring? Whats the vig on one of those, McMark? Paypal? |
McMark |
Jan 27 2012, 12:30 AM
Here's the info on the speedo drive mod. I can add an angle drive for $20.
Lo-Fi Version | Time is now: 15th May 2024 - 09:23 PM |
