advice on P.C.V. or Krank vent., venting advice for crank case,hose hook up to air box |
DRPHIL914 |
Jan 25 2012, 04:34 PM
I have no pcv valve just a hose from the oil filler location to the air box. Checking the hose, lots of moisture and oil residue. Question is should I get a pdf and put that there and where to get one. Next question is can I just cap that, or will this cause a crank case pressure- or lack of ventilation. I have the hose chart from jeff Bowlsby and I find it says pcv, - which I i dot not have right now.- bought it that way.
SLITS |
Jan 25 2012, 05:39 PM
Just ask for a filler assembly from a '73 - '74 2.0L ... it'll fit and has the PCV valve in it. I know there are others, but don't remember the years.
'75 - '76 won't have it. |
DRPHIL914 |
Jan 25 2012, 06:06 PM
Jan 25 2012, 06:28 PM
The valve is not in the air filter assembly. It's in the oil filler tower, next to the funnel that you pour the oil into.
http://members.rennlist.com/pbanders/PCV.htm What year is your 914, and which fuel system does it have? It may wind up better to use a "breather box" setup, particularly if you have carbs. --DD |
DRPHIL914 |
Jan 25 2012, 06:50 PM
The valve is not in the air filter assembly. It's in the oil filler tower, next to the funnel that you pour the oil into. http://members.rennlist.com/pbanders/PCV.htm What year is your 914, and which fuel system does it have? It may wind up better to use a "breather box" setup, particularly if you have carbs. --DD Its a 75 2.0 d-jet. |
914_teener |
Jan 25 2012, 08:56 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The valve is not in the air filter assembly. It's in the oil filler tower, next to the funnel that you pour the oil into. http://members.rennlist.com/pbanders/PCV.htm What year is your 914, and which fuel system does it have? It may wind up better to use a "breather box" setup, particularly if you have carbs. --DD Its a 75 2.0 d-jet. Last time I checked for this part No. at Porsche I was told NLA ? (IMG:style_emoticons/default/WTF.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 04:42 PM |
