Pedal board question |
Black914_4 |
Jan 27 2012, 09:01 AM
Member Group: Members Posts: 272 Joined: 11-January 12 From: AR Member No.: 13,994 Region Association: South East States |
Did all 914's come with a pedal board? Mine does not have one. If it is suppose to then I'll start looking for one.
Thanks |
dlestep |
Jan 27 2012, 09:31 AM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Did all 914's come with a pedal board? Mine does not have one. If it is suppose to then I'll start looking for one. Thanks Yes, they had pedal boards, with an adjustible clutch pedal stop. On the passenger side, my '73 had a molded foam piece, which I still have. My '74 didn't have anything, at least by the time I received it. |
rallysport70 |
Jan 27 2012, 11:32 AM
Member Group: Members Posts: 64 Joined: 1-May 09 From: Albany, NY Member No.: 10,321 Region Association: North East States |
My 74 did have the molded foam piece on the passenger side. A small piece broke when I was removing it. I simply glued it back together, can't really recall with what. I then painted it with bed liner from a can in an effort to make it more moisture resistant. I also painted the pedal board as well.
Black914_4 |
Jan 27 2012, 05:25 PM
I just found mine 5 min ago in the trunk (IMG:style_emoticons/default/headbang.gif)
I had almost thrown it away the other day with the other trash in there. I didn't know what it was. It is in two pcs and made out of crappy peg board material, but I can use it for a template to make a new one. |
Bob L. |
Feb 13 2012, 07:37 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I have the foam block in the passenger foot well too. What is it for?
It really takes legroom away from the passenger. I could put a sub-woofer there. |
Feb 13 2012, 09:22 PM
Resident German Group: Admin Posts: 41,622 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Pat Garvey |
Feb 14 2012, 06:08 PM
I just found mine 5 min ago in the trunk (IMG:style_emoticons/default/headbang.gif) I had almost thrown it away the other day with the other trash in there. I didn't know what it was. It is in two pcs and made out of crappy peg board material, but I can use it for a template to make a new one. The correct one should be made from simple plywood, with adjuster fitted, and painted black (satin, of course). Pegboard is wrong. Pat |
Pat Garvey |
Feb 14 2012, 06:11 PM
Did all 914's come with a pedal board? Mine does not have one. If it is suppose to then I'll start looking for one. Thanks Yes, they had pedal boards, with an adjustible clutch pedal stop. On the passenger side, my '73 had a molded foam piece, which I still have. My '74 didn't have anything, at least by the time I received it. The molded foam piece is interesting. When did they start using it, and why? My '72, which I am the original owner of, does not have it. Any other early 914's out there that do have it? Curious. |
Black914_4 |
Feb 14 2012, 07:05 PM
QUOTE The correct one should be made from simple plywood, with adjuster fitted, and painted black (satin, of course). Pegboard is wrong. Pat Here's a pic. Looks factory. It's same material as cheap pegboard. When I think of "plywood" I think of layers/ply's of wood like you build a house with. This is cheap crappy stuff. Attached thumbnail(s) |
porbmw |
Feb 14 2012, 11:12 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
I think the early cars had plywood, and the later ones....maybe 73 or so and later, had the crappy fiberboard ones....
I"m sure there's an expert out there that will state otherwise...or check the site for originality Friom your pic, I thnk you have a crappy factory one (IMG:style_emoticons/default/smile.gif) |
Black914_4 |
Feb 15 2012, 07:06 AM
I think the early cars had plywood, and the later ones....maybe 73 or so and later, had the crappy fiberboard ones.... I"m sure there's an expert out there that will state otherwise...or check the site for originality Friom your pic, I thnk you have a crappy factory one (IMG:style_emoticons/default/smile.gif) Mine is a '74 so that would fit. Good thing is I can still use it as a template to make a new one and save a couple $'s (IMG:style_emoticons/default/biggrin.gif) |
sixerdon |
Feb 15 2012, 08:27 AM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Did all 914's come with a pedal board? Mine does not have one. If it is suppose to then I'll start looking for one. Thanks Yes, they had pedal boards, with an adjustible clutch pedal stop. On the passenger side, my '73 had a molded foam piece, which I still have. My '74 didn't have anything, at least by the time I received it. The molded foam piece is interesting. When did they start using it, and why? My '72, which I am the original owner of, does not have it. Any other early 914's out there that do have it? Curious. I saw your pics in the nailed threads. That is interesting. According to Johnson's book, "......a larger foam filler was installed under the carpet to shorten the footwell. This significant change occurred at the same time when retractable seat belts were added." Dare I say you have an anomaly? A friend of mine has a June '72 /4, also. I'll check that out this weekend if I have time. Don |
Pat Garvey |
Feb 16 2012, 05:30 PM
Did all 914's come with a pedal board? Mine does not have one. If it is suppose to then I'll start looking for one. Thanks Yes, they had pedal boards, with an adjustible clutch pedal stop. On the passenger side, my '73 had a molded foam piece, which I still have. My '74 didn't have anything, at least by the time I received it. The molded foam piece is interesting. When did they start using it, and why? My '72, which I am the original owner of, does not have it. Any other early 914's out there that do have it? Curious. I saw your pics in the nailed threads. That is interesting. According to Johnson's book, "......a larger foam filler was installed under the carpet to shorten the footwell. This significant change occurred at the same time when retractable seat belts were added." Dare I say you have an anomaly? A friend of mine has a June '72 /4, also. I'll check that out this weekend if I have time. Don Who knows what evil lurked in the parts bins of transitional 914's! I wonder....did early 911's, late 356's, and for that matter water cooled cars have issues such as these? Don't wonder enough to search, but I'll bet they did - particularly cars produced "out of house", such as 924's, 944's, etc. |
dlestep |
Feb 16 2012, 10:55 PM
The foam piece was molded with the floor, hump, forward vertical bulkhead and right
wheel well and its' face is at the same angle as the pedal board. If anyone is interested, I can take a photo of it tomorrow. My roommate's 1971 914 had a center deposit and a separate foot rest that looked like a carpeted 2x4, and a non-adjustible passenger seat. My 1972 911 had a plywood pedal board. My 1973 914 had a pressboard pedal board and the foam piece on the passenger side. (It had a really thick black rubber mat on the rear bulkhead, behind the backpad.) My 1974 914 had a deteriorated pressboard pedal board and came with tan and black interior, black console with no foot rest on the passenger side. (Its' rubber matting was lighter in color and was half the thickness of the '73.) |
Lo-Fi Version | Time is now: 5th May 2024 - 11:50 AM |
