> If you dont know the right way..., 5 Lug conversion rear machining
736conver
post Aug 29 2004, 02:46 PM
Here's an example of what not to do. This guy came to me and said his wheels didnt fit right on his car and he has a vibration at higher speeds. He also said he did his own 5-lug conversion.
For those of you who dont have the right tools to do this dont do it. Also use quality parts too. The carnage is below.
736conver
post Aug 29 2004, 02:48 PM
Cheap wheel studs.....Looks like Bug Pack strikes again
736conver
These were then Hammer in.
736conver
post Aug 29 2004, 02:49 PM
Heres his way of countersinking.
736conver
post Aug 29 2004, 02:51 PM
He use a hand drill to make this. They werent straight and the holes were not milled right for the studs to sit flush. Here is the correct way to do it. Dont mind the piece of bearing still on the hub.
Brad Roberts
post Aug 29 2004, 02:53 PM
914 Freak!
Come on... everyone is trying to save a buck or two... (IMG:style_emoticons/default/laugh.gif) It takes 5 minutes to do it right. It takes 5 hours to fix it when it is wrong.
[B]
736conver
post Aug 29 2004, 02:57 PM
Not only that, he's out the whole $2.95 or whatever he spent on studs. (IMG:style_emoticons/default/wink.gif)
Plus new bearings at $35 a pop.
Didnt save a dime. Cost more in the long run.
Aaron Cox
post Aug 29 2004, 02:59 PM
Professional Tinkerer
are the hubs really strong enuff for the studs to hold without any additional bossed or hub thickness? i had a set and they were way to thin to put studs on IMHO without any sort of backing/boss
Brad Roberts
post Aug 29 2004, 03:01 PM
914 Freak!
This is why I get BIG money for the early rear hubs with the raised bosses for 5 lug. It has both patterns cast into it. I stopped counting how many conversion cars have loose rear studs because of the thin material.
B
J P Stein
post Aug 29 2004, 06:25 PM
Irrelevant old fart
QUOTE(Brad Roberts @ Aug 29 2004, 01:01 PM)
B
I figure I can sell my rear hubs and oil tank and get enuff to retire.....plan A.
Plan B is work till I die......
markb
post Aug 29 2004, 09:59 PM
914less :(
Damn, my plan A is your plan B.... (IMG:style_emoticons/default/sad.gif)
Aaron Cox
post Aug 29 2004, 10:02 PM
QUOTE(markb @ Aug 29 2004, 08:59 PM)
whats ur plan b? (IMG:style_emoticons/default/lol2.gif)
play the lotto until your broke? (IMG:style_emoticons/default/biggrin.gif)
redshift
Bless the Hell out of you!
I haven't even made plans..
(IMG:style_emoticons/default/unsure.gif)
M
machina
post Aug 29 2004, 10:08 PM
QUOTE(Brad Roberts @ Aug 29 2004, 05:01 PM)
Yup, I actually switched from the thin hubs to the early hubs with the raised bosses. Just piece of mind.
dr
McMark
post Aug 29 2004, 11:38 PM
914 Freak!
What about...
1. Machine off all bosses on the late style hub to get a nice flat circle.
2. Get a ring made of steel that you can then weld onto the newly machined surface.
3. Drill your holes and install your lugs in your new 360 degree thick hub.
Well?
Brad Roberts
post Aug 29 2004, 11:45 PM
914 Freak!
30lbs of rotating mass... We actually had a set of those floating around the shop. They weigh a ton when you are done.
B
post Aug 30 2004, 12:01 AM
Resident German
or, you could just get a set of these ...
(IMG:style_emoticons/default/wink.gif) Andy
McMark
post Aug 30 2004, 12:38 AM
914 Freak!
Spoken like a racer. (IMG:style_emoticons/default/bootyshake.gif)
watsonrx13
post Aug 30 2004, 04:34 AM
Brad, Andy's showing off again. (hahahahaha) (IMG:style_emoticons/default/biggrin.gif)
eeyore
post Aug 30 2004, 02:58 PM
QUOTE(Brad Roberts @ Aug 29 2004, 02:01 PM)
B
For re-drilled (and studded?) early model hubs, how many places to the left of the decimal point are we talking about filling?
Is installing converted 5 lug hubs a 'simple' (250 ft/lb) bolt on? If so, then I wouldn't need to source new stub axles, rotors, and calipers or worry about the parking brake issue either.
- Lo-Fi Version Time is now: 8th August 2026 - 10:57 AM
