> fuel or ignition ??
boomy
post Sep 1 2004, 06:14 AM
Hi, hope someone can help ....
The engine: 1.7 type 4 with twin dellorto's
The problem: turns over fine, but takes about 2-3 turns of the key before it will fire from cold...then it sort of starts, I try to use the gas pedal to get it going and it just dies..?? ....it does then start but recently after being left for a couple of weeks took about 5 minutes to start..
I have tried diferent start methods, all to no avail. It starts fine when it has been run that day or is quite warm..
I have checked the spark, cap/rotor arm, plugs etc and all look OK...it has got a new(ish) electronic ignition system.
Once up and running it is pretty much OK; it does backfire on overun a bit, but pulls fine...
Is this an ignition component breaking down or a fuel prob..the pump for instance ??
Any help appreciated ....thanks...Mark
mike_the_man
post Sep 1 2004, 06:32 AM
I like stuff!
I don't know much about carbs, but I'd say that it's probably normal for carbs to be hard to start when cold. If you don't have a choke, or any type of cold enrichment system, it's gonna be hard to start. I'm sure that somebody who knows more will speak up.
ArtechnikA
post Sep 1 2004, 06:59 AM
rich herzog
Dells have no chokes so they'll always be a bit finicky about starting.
Weber-equipped 914.6's came with a hand throttle to assist the warmup phase, but /4's don't have them.
the standard carburetor cold-starting procedure is to pump the throttle two or three times to provide a bit of cold-start enrichment. then crack the throttle -a little- and turn the key. don't play with the throttle much - you risk flooding.
don't know what pump you're using, or now it's connected, but that's almost never a factor in cold-start performance.
when it's playing hard-to-get, pull a plug and see what's goin on in there. if the plug is drippy wet with fuel, you need to add more steady throttle position - to add more air. DON'T PUMP. if they're dry, you may have a fuel delivery issue.
like Webers, Dellorto carbs tend to idle jet clogging, which will make starting hard, so make sure those are clear.
finally - make sure your valves are adjusted spot-on and your static spark advance is not too great.
oh - and welcome !
boomy
post Sep 2 2004, 12:39 AM
thanks ppl .... now I just need to tackle the handbrake situation !! (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/cool.gif)
- Lo-Fi Version Time is now: 12th July 2025 - 06:48 AM
