TO arm freeplay, how much again? |
machina |
Sep 1 2004, 06:58 AM
Now that the tranny is bolted up, was checking the freeplay of the are. I seem to remember 20mm freeplay, but is that at the end of the arm (which would be longer) or at the point where it touches the case?
How much is too much? dr |
machina |
Sep 1 2004, 10:36 AM
(IMG:style_emoticons/default/icon_bump.gif) hello?
dmenche914 |
Sep 1 2004, 02:13 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
I do not know the diminsion, however you want a clutch pedel to have about half an inch of free play before it starts pulling on the arm. If you find you do not have enough travel to fully release the clutch when pedel free play is correct, you either need to move the stop under the pedel further down, or (especially true if new tranny) make sure you have enough washers to shim the ball that the arm pivots on. This ball , if too close to the tranny because not enough washer spacers under it, will not allow the arm to move enought to fully disengage the clutch.
(I know this cuase it was a real pain one time to figure out what was wrong, had the tranny in and out four times or so in one day.) dave |
Lo-Fi Version | Time is now: 6th May 2024 - 07:01 AM |
