from spain another 914 restoration |
jm993rs |
Apr 17 2012, 02:09 PM
Member Group: Members Posts: 68 Joined: 29-August 11 From: Mallorca Member No.: 13,498 Region Association: None |
now the car is here !!! (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/welder.gif)
Attached thumbnail(s) |
Apr 17 2012, 02:22 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
rnellums |
Apr 17 2012, 03:03 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/piratenanner.gif) Que linda! Ojala que tenga tanto dedicacion en mis proyectos! Sigue! (IMG:style_emoticons/default/aktion035.gif)
type47fan |
Apr 17 2012, 09:50 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
JM, you have a great project. It is wonderful that you are saving another 914 from neglect and deterioration.
Have you listed your VIN in the 914World member's VIN database? Here is the link to it: http://www.914world.com/bbs2/index.php?act=membervins Keep the pics coming! Thanks, |
jm993rs |
Apr 23 2012, 01:31 PM
Please, where I can buy this part ?????????
Please input the Url´s of where !! Thank you guys !! Attached image(s) |
Apr 23 2012, 01:43 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Please, where I can buy this part ????????? Please input the Url´s of where !! Thank you guys !! If that is a JWest/Rennshifter part, I'm pretty sure it is no longer available. Tangerine racing has something similar. http://www.tangerineracing.com/transmission.htm or PMS - http://www.patrickmotorsports.com/part/595/ |
Series9 |
Apr 23 2012, 03:02 PM
Please, where I can buy this part ????????? Please input the Url´s of where !! Thank you guys !! If that is a JWest/Rennshifter part, I'm pretty sure it is no longer available. Tangerine racing has something similar. http://www.tangerineracing.com/transmission.htm or PMS - http://www.patrickmotorsports.com/part/595/ (IMG:style_emoticons/default/agree.gif) |
jm993rs |
Jun 12 2012, 08:46 AM
Now I have a little problem !!!!!!
I thinked for the conversion of 5 front lug nuts, I need the front hubs of the 911 and I have but........................ why else ??? please anybody have one DYS ??? |
jm993rs |
Sep 24 2012, 06:23 AM
(IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif)
now I have a little or big problem ??????? My car is of the year 73, I buy the car without engine and without gearbox, and in the time I buy one 914 gearbox to other seller from another 914, and now I have the gearbox mounted on the 911 2.4 engine and the system of the gearbox contra is not the same !!!!!!! THE gearbox is from one car of 71 and my car with the control of the gears is from 73 !!!!!!!!!! please !!!! the "gurus 914" of this forum, I need help help help !!!!!! what need can make ????? (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/screwy.gif) Attached thumbnail(s) |
hot_shoe914 |
Sep 24 2012, 07:03 AM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
You can buy the parts to convert your tail shift to a side shift. Either that or get a side shift gearbox.
FourBlades |
Sep 24 2012, 11:22 AM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Very nice project! John |
Sep 24 2012, 12:03 PM
now I have a little or big problem ??????? Can't help you with your problem but i can tell you that you will *not* like that 4-puck racing clutch you have there. I ran that exact clutch on my car and it was the worst clutch i have ever driven. It's basically like an on/off switch and almost impossible to do any sort of smooth engagement. You'll be much, much happier with a more streetable version. Or, if you really need the extra clamping force, go with a KEP Stage II clutch instead. (IMG:style_emoticons/default/popcorn[1].gif) |
Sep 24 2012, 05:29 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It may not be that easy to get a side-shift transmission in Spain. Still worth looking for.
As I said on the Pelican thread, you can convert your new (tail-shift) transmission to the side-shift configuration using the parts from your old gearbox. Worth cleaning things up and inspecting the bits inside while you have it apart, which can quickly turn into a gearbox rebuild. Dr. Evil over here has a pretty good video (2 DVD set) on how to do that rebuild, in case you go that way. Most people find that the regular side-shift's rear shift rod (which goes from the firewall to the transmission) will hit the 914-6 exhaust at some point in its travel. The popular solution is to fasten both ends of the shift rod to a jig (or just a board) so you can cut out the middle, and then weld in a straight piece of tubing or solid rod. --DD |
jm993rs |
Sep 26 2012, 04:06 AM
AND WHERE IS POSSIBLE BUY THE DR.EVIL'S VIDEOS OF 901 ????? I'M FROM SPAIN !!! CAN HE SEND TO ME ??? WHERE MAKE THE PAYMENT ??? THANK YOU !!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
cary |
Sep 26 2012, 07:27 AM
http://www.914world.com/bbs2/index.php?showtopic=113587
Right here on 914World in the Member Vendors forum. |
porbmw |
Sep 26 2012, 11:00 AM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
You got way more done in a few months than I have in a few years.
Slow down, boy, you're making me look bad.... (IMG:style_emoticons/default/poke.gif) But nice job...and I've always loved that color on that car..great look! |
jm993rs |
Nov 29 2012, 10:00 AM
Hellow 914 friends !!!
Now the car is here, is not finished with the herders and gearbox, but the bodywork is finished !!!! Now I think I need more information of this authentic green model, because more people make to me a lot of questions, races, where,pics, and more information of this racer original car !!! Anybody can input here more information ?? please.......... pics of the original, where win race's, diferents pilots etc etc Attached thumbnail(s) |
jm993rs |
Nov 29 2012, 10:04 AM
more pics
DonTraver |
Nov 29 2012, 10:39 AM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
So where are you exactly? I'm planning on going back to Spain next year with my RS America Porsche.
Maybe we could meet up for coffee/dinner, go for a drive, etc. Later, Don |
Bob L. |
Nov 29 2012, 11:02 AM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
(IMG:style_emoticons/default/cheer.gif)
Wow. Es muy bonita! Felicidads (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 05:04 PM |
