Radiator shroud |
Radiator shroud |
13b914 |
Feb 6 2012, 06:51 PM
Member Group: Members Posts: 75 Joined: 2-August 07 From: Youngstown Florida Member No.: 7,963 Region Association: None |
I'm almost finished with the fan shroud and the shroud to guide the air into the radiator. All that is left is to cut the hole for the fan.
pcar916 |
Feb 6 2012, 06:52 PM
Fun!
914.SBC |
Feb 6 2012, 07:10 PM
Member Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None |
oldschool |
Feb 6 2012, 11:38 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
914.SBC |
Feb 7 2012, 08:28 AM
By the look of his avatar name its a Rotary I am such a rookie and have so much to learn. ...13b, duh. (IMG:style_emoticons/default/huh.gif) |
bulitt |
Feb 7 2012, 08:31 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Who makes that radiator and size? thanks
Rotary'14 |
Feb 7 2012, 09:37 AM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Your radiator shrouding and cutout looks really good! I want to see the video of it running. (so I can get fired up) Keep up the pictures!
-Robert |
13b914 |
Feb 7 2012, 03:04 PM
Thanks for the kind words. The radiator is a AFCO 80133N from Summit. It's going to be a while before it runs. The car is stripped for paint. I finished up the fan today. Now I have to pull it back apart and polish it up from all the scratches.
chuckc |
Feb 7 2012, 03:18 PM
Member Group: Members Posts: 196 Joined: 30-August 10 From: Astoria NY Member No.: 12,123 Region Association: North East States |
great job! how are you going to route the hoses?
peace, Chuck |
Mike Bellis |
Feb 7 2012, 03:40 PM
At the front, under the hood latch, weld a vertical strap down to the bottom. The PO of mine when it was still V8, cut it like yours and used the latch. Over time, the air pressure on the front of the car will cause the steel to lift. Your hood will not sit correctly... Nice Shroud!
13b914 |
Feb 7 2012, 03:47 PM
Thanks for the heads up on the hood. I will be using hood pins, thats what the 2 triangle pieces are in the corners. Do you think I will still have the hood issue? The hoses will get routed through the hole thats in the pic.
andys |
Feb 7 2012, 04:21 PM
13b914,
I'm using the AFCO 80133N as well. In your photos, it looks as though the top and bottom hose connections are the same size. Mine are 1 1/4" top, and 1 3/4" bottom. Perhaps they only look the same in your photos? +1 on the extra vertical strap. How is your radiator secured to the ducting? I'd avoid hard mounting it. Andys |
13b914 |
Feb 7 2012, 04:26 PM
Mine is the same as yours on the inlet and outlet. It's not hard mounted. It's floating between th cradle at the bottom and another mount up top.
andys |
Feb 7 2012, 04:49 PM
Mine is the same as yours on the inlet and outlet. It's not hard mounted. It's floating between th cradle at the bottom and another mount up top. I made a U channel on three sides lined with 1/4" foam, then pushed the radiator down into that. No metal contact anywhere. Andys |
13b914 |
Feb 7 2012, 04:52 PM
That's pretty much the same way I have it.
oldschool |
Feb 7 2012, 07:15 PM
13b914, I'm using the AFCO 80133N as well. In your photos, it looks as though the top and bottom hose connections are the same size. Mine are 1 1/4" top, and 1 3/4" bottom. Perhaps they only look the same in your photos? +1 on the extra vertical strap. How is your radiator secured to the ducting? I'd avoid hard mounting it. Andys Andy...you running a rotary also. (IMG:style_emoticons/default/huh.gif) |
oldschool |
Feb 7 2012, 07:21 PM
Thanks for the heads up on the hood. I will be using hood pins, thats what the 2 triangle pieces are in the corners. Do you think I will still have the hood issue? The hoses will get routed through the hole thats in the pic. Now this is a green way to go..... (IMG:style_emoticons/default/lol-2.gif) Attached thumbnail(s) |
andys |
Feb 8 2012, 10:40 AM
No rotary; LS1. I do know the rotary requires a good (large) cooling system, so going with a V8 sized radiator seems like a safe bet. Andys |
13b914 |
Feb 14 2012, 06:55 PM
I finsihed covering the openings in the wheel wells. I covered them with wire mesh. It turned out OK.
Lo-Fi Version | Time is now: 17th May 2024 - 03:03 PM |
