13b914
Feb 6 2012, 06:51 PM
I'm almost finished with the fan shroud and the shroud to guide the air into the radiator. All that is left is to cut the hole for the fan.
Click to view attachmentClick to view attachmentClick to view attachment
pcar916
Feb 6 2012, 06:52 PM
Fun!
914.SBC
Feb 6 2012, 07:10 PM
QUOTE(pcar916 @ Feb 6 2012, 04:52 PM)
Fun!
What type of conversion you doing?
oldschool
Feb 6 2012, 11:38 PM
By the look of his avatar name its a Rotary
914.SBC
Feb 7 2012, 08:28 AM
QUOTE(oldschool @ Feb 6 2012, 09:38 PM)
I am such a rookie and have so much to learn. ...13b, duh.
bulitt
Feb 7 2012, 08:31 AM
Who makes that radiator and size? thanks
Rotary'14
Feb 7 2012, 09:37 AM
Your radiator shrouding and cutout looks really good! I want to see the video of it running. (so I can get fired up) Keep up the pictures!
-Robert
13b914
Feb 7 2012, 03:04 PM
Thanks for the kind words. The radiator is a AFCO 80133N from Summit. It's going to be a while before it runs. The car is stripped for paint. I finished up the fan today. Now I have to pull it back apart and polish it up from all the scratches.
chuckc
Feb 7 2012, 03:18 PM
great job! how are you going to route the hoses?
peace,
Chuck
Mike Bellis
Feb 7 2012, 03:40 PM
At the front, under the hood latch, weld a vertical strap down to the bottom. The PO of mine when it was still V8, cut it like yours and used the latch. Over time, the air pressure on the front of the car will cause the steel to lift. Your hood will not sit correctly... Nice Shroud!
13b914
Feb 7 2012, 03:47 PM
Thanks for the heads up on the hood. I will be using hood pins, thats what the 2 triangle pieces are in the corners. Do you think I will still have the hood issue? The hoses will get routed through the hole thats in the pic.
andys
Feb 7 2012, 04:21 PM
13b914,
I'm using the AFCO 80133N as well. In your photos, it looks as though the top and bottom hose connections are the same size. Mine are 1 1/4" top, and 1 3/4" bottom. Perhaps they only look the same in your photos?
+1 on the extra vertical strap.
How is your radiator secured to the ducting? I'd avoid hard mounting it.
Andys
13b914
Feb 7 2012, 04:26 PM
Mine is the same as yours on the inlet and outlet. It's not hard mounted. It's floating between th cradle at the bottom and another mount up top.
andys
Feb 7 2012, 04:49 PM
QUOTE(13b914 @ Feb 7 2012, 02:26 PM)
I made a U channel on three sides lined with 1/4" foam, then pushed the radiator down into that. No metal contact anywhere.
Andys
13b914
Feb 7 2012, 04:52 PM
That's pretty much the same way I have it.
oldschool
Feb 7 2012, 07:15 PM
QUOTE(andys @ Feb 7 2012, 02:21 PM)
13b914,
Andys
Andy...you running a rotary also.
oldschool
Feb 7 2012, 07:21 PM
QUOTE(13b914 @ Feb 7 2012, 01:47 PM)
Click to view attachmentNow this is a green way to go.....
andys
Feb 8 2012, 10:40 AM
QUOTE(oldschool @ Feb 7 2012, 05:15 PM)
No rotary; LS1. I do know the rotary requires a good (large) cooling system, so going with a V8 sized radiator seems like a safe bet.
Andys
13b914
Feb 14 2012, 06:55 PM
I finsihed covering the openings in the wheel wells. I covered them with wire mesh. It turned out OK.
