Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
Eric_Shea |
Feb 29 2012, 09:25 AM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Interesting Mark. So if I pull my stalk and activate the pump, it should run the wipers what; 4 times? But you're saying the load from the pump will affect this?
Bartlett 914 |
Feb 29 2012, 01:54 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Interesting Mark. So if I pull my stalk and activate the pump, it should run the wipers what; 4 times? But you're saying the load from the pump will affect this? Hi Eric The relay for the intermittent wipers will not work properly if you add a washer pump to the circuit. The resistance of the relay coil or the pump motor will render the intermittent inoperative. The circuit I made solves this problem. It is a high impedance relay driver. That is, the power to pull the relay is very low. Somewhere TTL signal level. The relay coil and the motor windings are low resistance. I made a perf board circuit as shown in the other thread. It is small and can be hidden. I may have another one I can send you or you can make your own. |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:28 PM |
