Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
Krieger |
Feb 29 2012, 08:55 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I put a 16 amp in and put the wiper switch all the way up, key on, zap! it immediately fried.
Valy |
Feb 29 2012, 09:17 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I put a 16 amp in and put the wiper switch all the way up, key on, zap! it immediately fried. OK. No more destructive tests for now. I assume that the wipers didn't move at all, correct? take out the connector from the switch and measure the resistance between the wires and ground. here is what you should get: green/white 0 ohm or very low Red/white infinite. black purple will read the motor resistance Black blue should read higher resistance than previous one. If all is good, next the switch will need to come out. If that's not an isstrue, you can take it out now to test the wires as crawling under it is a PITA. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:01 AM |
