Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
SirAndy |
Feb 6 2012, 10:34 PM
Resident German Group: Admin Posts: 41,614 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? I'm pretty sure the wires you need weren't part of the main harness and switch until '73/'74. So, even if you used the later switch portion, your harness would still be missing the correct wires. It's been a while, so a may be wrong about this ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 04:13 AM |
