Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
Eric_Shea |
Feb 28 2012, 01:01 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Update.
Many Thanks to Valy for the countless e-mails and assistance. I have my front trunk completely wired now. IMPORTANT: I used the 924 7-pin but, it does not fit in a 914 steering column. The 914 column is only wide enough to support the 6-pin. I was able to use the plastic plug pieces from my 914 switch and make it work. Now I have the intermittent wiper relay and a lead off the switch to activate the pump. Just a heads up to anyone thinking of using the 924 switch. |
Lo-Fi Version | Time is now: 4th May 2024 - 12:39 AM |
