Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
Bartlett 914 |
Feb 29 2012, 08:35 AM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I did a little research on this as well. If you want intermittent wipers and use the signal to trigger a relay for the washer pump, you will have a problem. The load on from the washer pump relay will not allow the intermittent wiper to operate properly. My solution was to add a high impedance relay driver circuit. It is very simple and easy to make. Intermittent wipers and washer pump without an extra switch.
Wiper discussion |
Lo-Fi Version | Time is now: 4th May 2024 - 04:12 AM |
