Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
Eric_Shea |
Feb 29 2012, 09:25 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Interesting Mark. So if I pull my stalk and activate the pump, it should run the wipers what; 4 times? But you're saying the load from the pump will affect this?
Valy |
Feb 29 2012, 09:44 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Interesting Mark. So if I pull my stalk and activate the pump, it should run the wipers what; 4 times? But you're saying the load from the pump will affect this? Eric, you're good. Your switch has separateed contacts for the pump and relay. There were some out there that tried to use the same (brown/black) wire for both functoins. |
Lo-Fi Version | Time is now: 4th May 2024 - 03:04 AM |
