Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
Cap'n Krusty |
Feb 7 2012, 02:56 PM
A switch from a '77 924, Rabbit, or Scirocco works. It's NLA, though.
The Cap'n |
Valy |
Feb 7 2012, 05:47 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
A switch from a '77 924, Rabbit, or Scirocco works. It's NLA, though. The Cap'n There are reproductions available. Not great but good enough. http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G |
Krieger |
Feb 28 2012, 10:37 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
[/quote] There are reproductions available. Not great but good enough. http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G [/quote] Dang! I bought part # 111-953-519 H based on someones post here a long time ago. Every time I turn it on a fuse burns out. Good thing I really don't drive in the rain. Any ideas as to the difference between the G and the H models? Is there a way to tweak mine? The steering/lock assembly on my car is a 74 model. Car is a 75. |
Valy |
Feb 28 2012, 11:01 PM
[quote name='Krieger' date='Feb 28 2012, 08:37 PM' post='1636033']
[/quote] There are reproductions available. Not great but good enough. http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G [/quote] Dang! I bought part # 111-953-519 H based on someones post here a long time ago. Every time I turn it on a fuse burns out. Good thing I really don't drive in the rain. Any ideas as to the difference between the G and the H models? Is there a way to tweak mine? The steering/lock assembly on my car is a 74 model. Car is a 75. [/quote] I have exactly that switch in my 74 and it works fine. I can try to help but you need to provide more details. Which fuse Burns? What exactly you turn on? What's connected to the switch? Have you done any modification? Pictures help very much. |
Krieger |
Feb 29 2012, 07:59 PM
Which fuse Burns? -5th one from right, it has the wiper/cig lighter on cover.
What exactly you turn on? When I turn on the wipers the motor starts to move then the fuse cooks What's connected to the switch? All stock...except hot wire for cig lighter powers vdo fuel gauge, which functions correctly. Have you done any modification? Pictures help very much. The harness is all stock otherwise. I do not have anything fancy added for the wipers. Car is 75. I replaced the 75 plastic steering column housing, with an earlier 73/4 metal unit. This is the assembly that holds the key/lock, wiper washer, turn signal ???? |
Lo-Fi Version | Time is now: 3rd May 2024 - 11:47 PM |
