Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
Krieger |
Feb 29 2012, 11:03 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Just got an old wiper switch of unknown origin. Plugged it in turn on ignition flick switch, wiper works no problems....
Valy |
Mar 1 2012, 12:42 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Just got an old wiper switch of unknown origin. Plugged it in turn on ignition flick switch, wiper works no problems.... Hm..... Numbers don't make sense but never mind that now. You should'be say you have a replacement (IMG:style_emoticons/default/smile.gif) Take some pictures of the switch guts. Let's see what's wrong. |
Lo-Fi Version | Time is now: 4th May 2024 - 11:43 AM |
