Wiper switch differences, trying to add an elec. washer switch |
peteyd |
Feb 6 2012, 10:06 PM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I am trying to figure out what I have here. I noticed that there are two different wiper switches available. 70-72 and 73-76.
This is the one that is in the best condition. Notice that it only has four pins on the left side. I have already attached a switch that I got from davep, which will trigger my electric washer pump that I plan to install. This is the second one that I have. Being in worse condition out of the two. It has five pins on the left side. The extra one being a brown, which is ground correct? The switch is also different in that the plunger that would activate the washer fluid has an electrical contact I am running a wiring harness from a 72 car. Which switch do I need to use? Am i missing pieces from the first switch maybe? Im stumped here... Pete |
Krieger |
Mar 1 2012, 09:16 PM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Hey, I'm at it again.
Here are some observations: The old unknown switch works wipers and does not pop fuse when installed in steering assembly as well. The "new" switch works the wipers and does not pop the fuse when it is out of the assembly.... I 'm gonna study these switches and see if I can find out why. |
Lo-Fi Version | Time is now: 4th May 2024 - 04:03 AM |
