| Eric_Shea |
Feb 29 2012, 09:25 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Interesting Mark. So if I pull my stalk and activate the pump, it should run the wipers what; 4 times? But you're saying the load from the pump will affect this?
| Valy |
Feb 29 2012, 09:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Interesting Mark. So if I pull my stalk and activate the pump, it should run the wipers what; 4 times? But you're saying the load from the pump will affect this? Eric, you're good. Your switch has separateed contacts for the pump and relay. There were some out there that tried to use the same (brown/black) wire for both functoins. |
| Eric_Shea |
Feb 29 2012, 10:01 AM
Whew...
| Bartlett 914 |
Feb 29 2012, 01:54 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,219 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Interesting Mark. So if I pull my stalk and activate the pump, it should run the wipers what; 4 times? But you're saying the load from the pump will affect this? Hi Eric The relay for the intermittent wipers will not work properly if you add a washer pump to the circuit. The resistance of the relay coil or the pump motor will render the intermittent inoperative. The circuit I made solves this problem. It is a high impedance relay driver. That is, the power to pull the relay is very low. Somewhere TTL signal level. The relay coil and the motor windings are low resistance. I made a perf board circuit as shown in the other thread. It is small and can be hidden. I may have another one I can send you or you can make your own. |
| Bartlett 914 |
Feb 29 2012, 02:23 PM
IIRC the brown white wire to the intermittent relay uses 3 signal levels. At ground, the intermittent wiper function is off. Pulse to 12 volts (as in a wiper stalk pull) and the intermittent relay will cause the wipers to give a few wipes. Open, and the intermittent function works. Changing the resistance to some extent (not enough to be useable) will change the delay time. If you put a relay with one grounded to this connection Washer pump coil or relay coil), the signal to the intermittent relay will appear to be grounded and no intermittent function.
| Valy |
Feb 29 2012, 02:26 PM
DELETED
| Krieger |
Feb 29 2012, 07:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,901 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Which fuse Burns? -5th one from right, it has the wiper/cig lighter on cover.
What exactly you turn on? When I turn on the wipers the motor starts to move then the fuse cooks What's connected to the switch? All stock...except hot wire for cig lighter powers vdo fuel gauge, which functions correctly. Have you done any modification? Pictures help very much. The harness is all stock otherwise. I do not have anything fancy added for the wipers. Car is 75. I replaced the 75 plastic steering column housing, with an earlier 73/4 metal unit. This is the assembly that holds the key/lock, wiper washer, turn signal ???? |
| Valy |
Feb 29 2012, 08:15 PM
Try this:
ignition off. Put the which in high speed position and turn on the switch. If the wipers work then your short is in the return line from the motor to switch. |
| Krieger |
Feb 29 2012, 08:55 PM
I put a 16 amp in and put the wiper switch all the way up, key on, zap! it immediately fried.
| Valy |
Feb 29 2012, 09:17 PM
I put a 16 amp in and put the wiper switch all the way up, key on, zap! it immediately fried. OK. No more destructive tests for now. I assume that the wipers didn't move at all, correct? take out the connector from the switch and measure the resistance between the wires and ground. here is what you should get: green/white 0 ohm or very low Red/white infinite. black purple will read the motor resistance Black blue should read higher resistance than previous one. If all is good, next the switch will need to come out. If that's not an isstrue, you can take it out now to test the wires as crawling under it is a PITA. |
| Krieger |
Feb 29 2012, 09:27 PM
Wipers didn't move. I am going to pull out the steering wheel now.
| Krieger |
Feb 29 2012, 09:55 PM
So I am measuring between the ground terminal on the plug (body harness) that goes into the back of the wiper switch and the other wires on that same plug?
here is what you should get: green/white 0 ohm or very low---dont have a green/white, i have a black/green white Red/white infinite.---red/gey?... black purple will read the motor resistance---dont have Black blue should read higher resistance than previous one.--dont have My wires don't really match your descriptions... |
| Krieger |
Feb 29 2012, 10:14 PM
Plug
Attached thumbnail(s) |
| Valy |
Feb 29 2012, 10:26 PM
That's the signal switch connector. Look at the other one, smaller.
And use the car body for ground please. |
| Krieger |
Feb 29 2012, 10:34 PM
Doh! I figured that out and this is what I'm getting
green/white infinity!!!!? black/ blue 0 black/ purple 0 red/black infinity |
| Valy |
Feb 29 2012, 10:44 PM
OK.
Green/white shows that your wipers are probably not completely parked. Don't worry about that for now. The other two black ones show that your wiper motor is probably history or you have a short in the harness. Can you switch the meter to the lowest ohm scale and repeat the measurement. You should get different readings, black/blue should be higher. If bothe are still 0 it may be the harness. |
| Krieger |
Feb 29 2012, 10:53 PM
black/purple 10.7
black/blue 10.2 |
| Krieger |
Feb 29 2012, 11:03 PM
Just got an old wiper switch of unknown origin. Plugged it in turn on ignition flick switch, wiper works no problems....
| Eric_Shea |
Feb 29 2012, 11:19 PM
Andy... It's your switch. (IMG:style_emoticons/default/wink.gif)
Happy to help! (IMG:style_emoticons/default/biggrin.gif) |
| Valy |
Mar 1 2012, 12:36 AM
Eric, I knew you're going to master it! (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 19th November 2026 - 06:10 PM |
