Floor pan question |
flowerfish |
Feb 7 2012, 06:05 PM
Newbie Group: Members Posts: 12 Joined: 6-March 11 From: Hawaii Member No.: 12,796 Region Association: Hawaii |
There is a damage under Pedal Cluster when I'm deciding to replace the spring , because the brake return spring was rust and the clutch spring broke , I'm afraid if I take off the set out will make more hole , it better replace the floor . because my car was really rusty under . Just fix the passenger side by sheet metal , and now found out more damage .
now , I get a question , if I order the whole floor pan , which one better ? front and rear 2 piece , or left and right ? I have check stoddard , pelicanparts , autoatlanta anybody have done this , of course I just order the parts , someone will help me work on it . |
Valy |
Feb 7 2012, 06:22 PM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Aloha!
The 2 options for the floor-pan have different coverage in the pedal cluster area. I don't know what will be better for you but this will probably be your decision point. BTW, I'll be on the Big Island in March (IMG:style_emoticons/default/smile.gif). Too bad I can't bring my car with me. |
bandjoey |
Feb 7 2012, 06:42 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
(IMG:style_emoticons/default/welcome.png) Restoration Design. See the vendor section. Good Luck and pictures will help us hep you too.
Feb 7 2012, 07:42 PM
914-6 GT in waiting Group: Members Posts: 19,278 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/welcome.png) Restoration Design. See the vendor section. Good Luck and pictures will help us hep you too. (IMG:style_emoticons/default/agree.gif) I bought a lot of steel from resto design. Good people, good product. Lots of good threads on floor pan replacement. |
flowerfish |
Feb 8 2012, 03:25 AM
it because left and right is look like not include the central part , I think that way is more easy and less cutting , front and rear look like more solid .... that why I don't know which one better
burton73 |
Feb 8 2012, 02:21 PM
burton73 Group: Members Posts: 3,526 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
it because left and right is look like not include the central part , I think that way is more easy and less cutting , front and rear look like more solid .... that why I don't know which one better I think you may find that you may have rust in the pan and in the area under the pan where the Pedal Cluster bolts up to the pan. It sits low there and water wants to collect in there. You get the front section of the pan and the Pedal Cluster reinforcement piece from Restoration Design or AA. Go where you get your best deal on freight to you. I put a front and back as I wanted to fix my clutch tube the right way. I had a problem there that the PO did not fix right. I went with front and back as I thought it gave me a cleaner pan look. You get ½ right/ left or ½ front /back. They cover the center. Bob (IMG:style_emoticons/default/welcome.png) |
jimkelly |
Feb 8 2012, 03:10 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 20th May 2024 - 05:46 PM |
