Clutch cable, One better than another |
spunone |
Sep 3 2004, 02:05 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
This may seem like a lame question but is there a particular type of cable thats better than another.or are they all the same?Just wanted to know who makes the best.
SpecialK |
Sep 3 2004, 02:28 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
I think the general consensus is the "Terry Cables" are the best.
Part Pricer |
Sep 3 2004, 02:35 PM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
QUOTE(Special_K @ Sep 3 2004, 03:28 PM) I think the general consensus is the "Terry Cables" are the best. I didn't particpate in that vote. (IMG:style_emoticons/default/biggrin.gif) A Gemo cable works just fine. Save your money on the cable and apply it somewhere else where it is going to make a diference. |
thomasotten |
Sep 3 2004, 07:54 PM
Senior Member Group: Members Posts: 1,545 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
(IMG:style_emoticons/default/agree.gif) I have tried the heavy duty kind, and I don't think they are any better. They all stretch. If you are having to adjust it all the time, check your firewall for cracks.
J P Stein |
Sep 3 2004, 07:59 PM
Me too, I didn't get polled....well, you know what I mean (IMG:style_emoticons/default/biggrin.gif)
Factory part is my favorite. The one in my car has been in there since before I bought the car.....ah...6-7 years ago....+ god knows with the PO. |
Brad Roberts |
Sep 3 2004, 08:09 PM
The Terry cables are MUCH smoother. Test me the next time you see me. Have me sit in two different cars (one with each cable) and I can tell you in a nanosecond which one has the Terry. The factory cable runs through a plastic sheath which creates drag on the cable for over 3 feet. The Terry doesnt do this.
B |
J P Stein |
Sep 3 2004, 08:16 PM
Nopers, the Terry cable creats drag on Fwd end of the clutch tube instead. (IMG:style_emoticons/default/cool_shades.gif)
Brad Roberts |
Sep 3 2004, 08:21 PM
Not unless the tube has been repaired incorrectly. I actually pay attention to how the cable exits the clutch tube (and throttle tube for that fact.) I stick a number 2 Phillips into the end of the clutch tube and move it depending on what it needs.
B |
thomasotten |
Sep 3 2004, 08:24 PM
It seems like you would want some plastic sheathing to keep dirt from clinging to the cable.
Brad Roberts |
Sep 3 2004, 08:29 PM
The Terry runs a much finer cable. Dirt only sticks to cables when they have grease on them.
B |
J P Stein |
What ever you say.....you're the guru. (IMG:style_emoticons/default/pray.gif)
Just a WAG, but I would think the factory puts the sheath on both the clutch & throttle cables specificly to keep the cables from rubbing on the tubes.....but WTF do I know (IMG:style_emoticons/default/confused24.gif) |
d7n7master |
Sep 3 2004, 08:32 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Another vote for TerryCables. Once installed, and re-adjusted after say a couple of weeks, done. No more streatch that I can tell. Plus, no lube req'd. Go figure.
Only wish that I had had TerryCables on my bug 15 years ago. When my clutch cable failed (back in the day) I had to shut it off & use the starter to get launched and crash gears to get home - more than a few times. |
Brad Roberts |
Sep 3 2004, 08:33 PM
They both work. One is just smoother than the other. The Terry will wear through the tube before it breaks.
Here is what pisses me off about the stock ones: (oH ..dont give me shit about the guru crap.. I didnt write it) When/if the white plastic sheeth brakes at the firewall (where it attaches to the black outer sheathing)... the assembly becomes worthless at that point even though the cable itself is fine. B |
airsix |
Sep 3 2004, 08:34 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
QUOTE(Paul Heery @ Sep 3 2004, 12:35 PM) Save your money on the cable and apply it somewhere else where it is going to make a diference. I'm totally with Brad on this one (Sorry JP). If the clutch tube is lined up correctly the cable doesn't drag on it at all. Terry cable = smooth. Stock cable = friction. You'd think that as long as a cable isn't broken that there's no reason to replace it. Wrong. I snapped a throttle cable and replaced it with a Terry cable and couldn't believe the difference. So smooth and light compared to the 30yr-old OEM cable (that was likely caked with dirt and corrosion). I'm actually glad the OEM cable broke - the new cable feels THAT MUCH BETTER. -Ben M. |
thomasotten |
Sep 3 2004, 08:35 PM
I am about to install one. It has been a while, do I need to grease the cable? Mine is a "Gemo" cable.
Brad Roberts |
Sep 3 2004, 08:37 PM
This sucks but I'm going to say it anyway...
I see 4-6 different 914's every week (physically work on them).. and have for several years. Clutch issues seam to be at the top of the "issues" list. How many people here knew that the 74 1.8 cars had WHITE throttle cables ? B |
J P Stein |
QUOTE(Brad Roberts @ Sep 3 2004, 06:33 PM) (oH ..dont give me shit about the guru crap.. I didnt write it) B Hay, somebody around here has to pull your chain once in a while......it was my turn (IMG:style_emoticons/default/laugh.gif) I have a new OEM spare should anything break.....doesn't everybody? |
Brad Roberts |
Sep 3 2004, 08:39 PM
Nope. I carry a Terry spare...LOL :finger2:
The key is: If you have never driven a car with Terry cables.. you will never no what the difference is. B |
J P Stein |
Sep 3 2004, 08:41 PM
It's OK, Ben....Larson is on my side (IMG:style_emoticons/default/biggrin.gif)
sgomes |
Sep 3 2004, 09:32 PM
Electric Member Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 |
I remember on some previous thread that the terry cables were sometimes longer than the stock cable. Is that the case or am I just (IMG:style_emoticons/default/smoke.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 05:10 PM |
