Keep blowing my hazard fuse |
ChrisReale |
May 2 2003, 10:53 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
WTF?? It takes an 8 amp fuse. I went through three 8 amps, eack would spark and blow before I put in a 16 amp. It works now. Why was it blowing fuses. I want to make sure everything is ok, not just patch it over...idea's?
Dave_Darling |
May 2 2003, 11:56 PM
Crap... Why couldn't it be a 74+ car, with the current flow diagram that is easy to understand??
OK, OK... Stuff that fuse #11 feeds: Buzzer. (I assume this is under the passenger's seat.) Emergency flasher switch. Interior light. That's it. So make sure that your interior light isn't unplugged, and make sure that the buzzer (whether undre the seat or up on top of the fuse panel, or wherever) isn't shorting out. Then unplug the black/red wire from the hazard switch and see if that helps. --DD |
Lo-Fi Version | Time is now: 18th May 2024 - 05:06 PM |
