12 point Alan wrench, what size |
02loftsmoor |
Feb 11 2012, 03:54 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
what size is the 12 point alan wrench for the CV joints 8mm or 6mm?
(IMG:style_emoticons/default/popcorn[1].gif) |
underthetire |
Feb 11 2012, 04:32 PM
You mean the special star socket? Someone here sells those.
rick 918-S |
Feb 11 2012, 04:38 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Twelve point, Triple square or serrated wrench. Can't remember the size.
billh1963 |
Feb 11 2012, 04:41 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Just used it today...8mm triple square
TheCabinetmaker |
Feb 11 2012, 05:41 PM
availavble at most flaps.
02loftsmoor |
Feb 11 2012, 09:08 PM
thanks guys (IMG:style_emoticons/default/biggrin.gif). What's flaps?
SLITS |
Feb 11 2012, 09:18 PM
FLAPS = Friendly Local Auto Parts Store ..
Go to a VW parts house and ask for the CV bolt tool. |
02loftsmoor |
Feb 11 2012, 09:31 PM
I knew that...... Thanks
abnrdo |
Feb 11 2012, 10:04 PM
Member Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
Autozone part number 25015. Worked great for me.
http://www.autozone.com/autozone/accessori...ifier=2357_0_0_ |
toolguy |
Feb 11 2012, 10:33 PM
Carquest has a 4 piece set, all the metric sizes we need. . If I remember correctly it was around $12
here's the link http://www.toolsource.com/triple-square-po...ic-p-67247.html |
shuie |
Feb 11 2012, 10:41 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Triple Square. 8mm. Check your local auto parts store.
02loftsmoor |
Feb 12 2012, 04:13 PM
picked up the bits from Auto zone 14 and some change,, thank you all (IMG:style_emoticons/default/wink.gif)
6freak |
Feb 13 2012, 08:25 AM
so ya got them out ! replace them with 6piont 8MM and drill them for safety wire...cheap insurance.. Or buy a set from someone here on the World.....JMO
MikeC (IMG:style_emoticons/default/smile.gif) |
02loftsmoor |
Feb 13 2012, 08:27 AM
Thank you for the tip. I will
TheCabinetmaker |
Feb 13 2012, 08:50 AM
Make sure you use a hammer to fully seat the tool in the bolt. You will hear and feel it when it bottoms. The factory bolts are fine if you clean them and use new Schnor washers. The tripple square is less likely to strip the bolt than the allen, if the tool is installed properly.
Cap'n Krusty |
Feb 13 2012, 09:14 AM
so ya got them out ! replace them with 6piont 8MM and drill them for safety wire...cheap insurance.. Or buy a set from someone here on the World.....JMO MikeC (IMG:style_emoticons/default/smile.gif) Here we go again. You guys all love so-called "upgrades", but when it comes to a real upgrade, you wanna go backwards. Early 914s used Allen (note the spelling and capitalization" or socket head bolts for the CV joints. They were "upgraded" (there's that beloved, but mostly mis-used, word again) to fasteners with a triple square drive because they'll take more torque safely without the irritating tendency to round off the socket (and the tool). Proper cleanliness, seating of the CV joint, and the use of new washers is the simplest way to prevent the properly torqued bolts from backing out. Safety wire is fine, but it's a PITA, and proper SS wire and the tool are pretty expensive. The Cap'n |
02loftsmoor |
Feb 13 2012, 09:33 AM
thank you i'll take all the tips and tricks I can
Make sure you use a hammer to fully seat the tool in the bolt. You will hear and feel it when it bottoms. The factory bolts are fine if you clean them and use new Schnor washers. The tripple square is less likely to strip the bolt than the allen, if the tool is installed properly. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:11 PM |
