Exhaust valve photos in car..., Normal or LEAN? |
RustyWa |
May 3 2003, 12:30 AM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
Pulled the exhaust off the heads tonight.....and here are some photos of what I found. I'm not sure what I'm looking at....is this normal for a car with 95k miles on it? I have no clue if this engine has ever been apart. To me I thought white means lean?
If you look closely, you can see the 50mm bolts I used for plugging the air injection ports. Cyl. 1 Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 04:02 AM |
