diggin into hell, Rustoration: You have to be strong |
michelko |
Sep 5 2004, 03:13 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi guys,
look what i found under the fender. The PO did some very fine work to repair the hell hole (IMG:style_emoticons/default/ar15.gif) Attached image(s) |
Brad Roberts |
Sep 5 2004, 09:24 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
WOW !!. That is crazy.
You did a great job with the brace. We normally use a larger/stronger "tube" with adjustable ends similiar to what you made. Put some preload in your adjuster. Make the car spread apart a few mm's more than a stocker. When you weld the car it will shrink when it cools. HOPEFULLY you will receive your parts from AA in a timely fashion. Next time you order anything from anyone stateside ASK THE CLUB first. The maker of that piece that supplies everyone is a member of this forum. B |
Lo-Fi Version | Time is now: 3rd May 2024 - 11:41 PM |
