diggin into hell, Rustoration: You have to be strong |
michelko |
Sep 5 2004, 03:13 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi guys,
look what i found under the fender. The PO did some very fine work to repair the hell hole (IMG:style_emoticons/default/ar15.gif) Attached image(s) |
SpecialK |
Sep 18 2004, 02:11 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
The flux core seems to do a dandy job on thicker metal, but I can't turn it down far enough to weld the sheet metal. Not much control over the voltage and feeds (min., max., high, low). I wonder if there's some way to wire potentiometers to replace the two position switches (IMG:style_emoticons/default/idea.gif)
I think I'll take your advice on the Gas MIG...I'll just rent one for now and see if I can't get some better results. Michelko, how do you say "You've got balls!" in German? (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 01:55 AM |
