914-6 Rear Valance, Will it work with a 914/4 exhaust? |
thomasotten |
Sep 5 2004, 11:26 PM
Senior Member Group: Members Posts: 1,545 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I saw this pic somewhere the other day, and it went straight into my 914 folder on my hard drive. I started to think about it, and what I liked about it was the rear valance. It hangs much lower on the 914/6, and looks more rounded. Is there any 914/4 exhaust that this will work with? I wouldn't necessarily need to put the tailpipe through the hole, that could be covered up, but I would like to run this valance.
ArtechnikA |
Sep 6 2004, 06:10 AM
most 914.6 owners took them off. i took one off each car, and they're gone forever, to that same lost warehouse in the sky with all the Pre-A 356 bumpers. if i knew then what i know now i'd have tried hard to keep track of them...
anyway - they add drag, they weigh something, and they increase engine temperatures at least 10F. if someone with an Asian car put on a part just for the look that made the car run worse, we'd be all over it... yes, the concours guys go ga-ga over original parts like that, and it's your car, do what you want. i wouldn't be holding my breath for an original /6 valence at a cheap price tho... |
seanery |
Sep 6 2004, 08:14 AM
yup, Rich is right!
There is a reason the factory went with a smaller valence after that. If you want to raise engine temps I have seen reproductions of that valence with and without the hole -I think it was AA. |
Kargeek |
Sep 6 2004, 11:23 AM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
I have the factory metal 6 valence on my car using a 2.0 muffler. I welded on a larger pipe to the muffler and used a six exhaust tip. I also added the two plastic foils or flaps on the edge of the chassis pan to increase airflow through the engine compartment. DH
smg914 |
Sep 6 2004, 12:49 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
All 914-4's and 914-6's in 1970 and 1971 used a rear lower valance that entirely covered the exhaust tip. There was a slight difference thought between the 6 and the 4 design. The hole on the 6 valance was further to the left. Or I guess you could say the hole on the 4 valance was further to the right. Many of the mail order houses sell aftermarket fiberglass versions of these larger rear valances.
type47fan |
Sep 6 2004, 12:58 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
The '72s had the larger valance, also. '73 was the first year for the short version.
Wayne (type47fan) |
Brad Roberts |
Sep 6 2004, 01:08 PM
Correct. The car above has a 4cyl porthole valence on it.
B |
echocanyons |
Sep 6 2004, 01:33 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Kargeek those are some interesting tailights you got I dont think I noticed them before.
Whats the scoop? |
Brad Roberts |
Sep 6 2004, 01:36 PM
Italian rears...
B |
echocanyons |
Sep 6 2004, 01:52 PM
Very cool, thanks Brad
Brad Roberts |
Sep 6 2004, 02:04 PM
I like them.
B |
Kargeek |
Sep 6 2004, 03:11 PM
At one time I had both of the early style "porthole" valances- the 4cyl version had the hole more to the right. I used the 6cyl version and my 2.0 muffler's tip would not fit through it so, I know I'm using the six valance. Drawings in the factory parts guide also show a porthole version with vertical cooling slats -however, I have never seen one. In addition to cooling Porsche shortened the valance because of snow build-up- the thing acted like a scoop for road debris.
Now, those taillights are correctly referred in the parts guide as "French" units. Something to do with France not allowing white lenses. I know a guy with a French spec. 70's Ferrari Lusso that has yellow headlights and he told me it had to do with France’s goofy motoring laws. DH |
thomasotten |
Sep 6 2004, 05:52 PM
Is it just this picture, or does the 914-6 rear valance actually arc forward, towards the front of the car? What I mean is that it continues to follow the arc of the tire down, even past what would be 3 O'clock.
ArtechnikA |
Sep 6 2004, 06:43 PM
QUOTE(echocanyons @ Sep 6 2004, 11:33 AM) Kargeek those are some interesting tailights you got I dont think I noticed them before. Whats the scoop? Italian are red and clear. amber backups are uniquely French. (not to contradict the Bradster ...) |
meursault |
Sep 6 2004, 11:07 PM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
QUOTE amber backups are uniquely French. I'll second that. Does this Frenchie car have yellow headlights too? |
Brad Roberts |
Sep 7 2004, 01:09 AM
Yep. I was thinking of the front Italian lenses.. clear.
All I know about the portholes: they trap heat and it shows up in oil temp and rear trunk temp. I know the 6 porthole doesnt fit a 914 4cyl stock muffer. The 6 porthole may fit 100's of other mufflers... but it does NOT fit the stock 4 cyl 2.0 muffler. I get guy's trying to sell us 4 cyl portholes because they *think* they are 9146 porthole valences.... the two are very different and the differences can be seen with the naked eye. B |
Lo-Fi Version | Time is now: 16th May 2024 - 07:28 PM |
