SOLD 1975-76 catalitic converter relay with harness |
Geezer914 |
Feb 15 2012, 07:00 AM
Geezer914 Group: Members Posts: 1,404 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
1975-76 catalitic converter relay and harness. $20 plus 6.35 shipping USPS priority mail.
Attached thumbnail(s) |
914runnow |
Feb 15 2012, 07:18 AM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
Sold..Payment to???
bdstone914 |
Feb 15 2012, 08:52 AM
bdstone914 Group: Members Posts: 4,518 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
sean_v8_914 |
Feb 15 2012, 09:03 AM
the box in the PAX foot well is a mile counter. the speedo cable goes thru it. it triggers the EGR service light every 30,000 miles
The sensor which controls the catalytic converter temperature is bolted directly to the catalytic converter and is connected to this relay, which is located next to the left taillight housing. |
sean_v8_914 |
this also triggers the CAT high temp warning light next to the tach
914werke |
Feb 15 2012, 10:16 AM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
the box in the PAX foot well is a mile counter. the speedo cable goes thru it. it triggers the EGR service light every 30,000 miles The sensor which controls the catalytic converter temperature is bolted directly to the catalytic converter and is connected to this relay, which is located next to the left taillight housing. Hmmm Ive never seen this ... do you have a pic of a installed setup? |
zonedoubt |
Feb 15 2012, 10:42 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
The sensor which controls the catalytic converter temperature is bolted directly to the catalytic converter and is connected to this relay, which is located next to the left taillight housing. Doesn't control, just measures. The sensors are usually burned up, I've been unsuccessful finding a replacement. |
914work |
Feb 15 2012, 12:18 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
So it attaches here?
sean_v8_914 |
Feb 16 2012, 08:34 AM
that paragraph is cut and paste from factory manual so if its wrong, talk to wofgang or Hans
sean_v8_914 |
Feb 16 2012, 08:56 AM
the sensor goes in teh cat where your plug cap is. the relay lives in teh rear trunk under teh left tail light biased toward the center. the sensor completed the relay circuit to trigger teh light on the dash next to the tach. I tried to paste a pic...
sean_v8_914 |
Feb 17 2012, 08:35 AM
the sensor is a bi-metallic switch. Mc Master Carr has them. the question is: what temperature do we need to complete the circuit to trigger teh relay? at what temp is a CAT too hot?
914work |
Feb 17 2012, 12:53 PM
So that port is on the muffler section on the inlet side of the CAT, not on the CAT itself.
The Port for the EGR feed pipe is on the Outlet side just before the final section & tailpipe. From what I understand shouldn't excessive cat temps be measured at the output, which would indicate too much un-burned hydrocarbons? |
matthepcat |
Feb 18 2012, 03:26 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Sweet. Always wondered what that was on my 75
914werke |
Feb 18 2012, 06:20 PM
Hey Admins, perhaps this should be moved to the Garage since it has turned into a more informational/discussion thread than an classified ad?
If thats OK with the Geezer? |
914runnow |
Feb 19 2012, 01:17 PM
Sold..Payment to??? Hi there...still awaiting info for payment to?? (IMG:style_emoticons/default/confused24.gif) Thanx Rx |
sean_v8_914 |
Feb 20 2012, 10:36 AM
if it moves, Ill take pics
914werke |
Feb 20 2012, 02:41 PM
Doesn't control, just measures. The sensors are usually burned up, I've been unsuccessful finding a replacement. They are available new link |
zonedoubt |
Feb 20 2012, 02:54 PM
(IMG:style_emoticons/default/idea.gif) Hmmm...must be a new product for them.
914runnow |
Feb 24 2012, 12:18 PM
Sold..Payment to??? Hi There..would still love to get this.. Thanx Rx (IMG:style_emoticons/default/piratenanner.gif) |
Geezer914 |
Feb 25 2012, 09:11 AM
914runnow sent you a PM.
Lo-Fi Version | Time is now: 12th May 2024 - 02:40 PM |
