How much does a set of Mahle 8:1 2.0L pistons cost? |
74porsche914 |
Feb 15 2012, 10:49 AM
Member Group: Members Posts: 59 Joined: 5-November 11 From: Highland Park, IL Member No.: 13,750 Region Association: Upper MidWest |
Trying to put an estimate together for my upcoming engine build.
SLITS |
Feb 15 2012, 10:52 AM
$1,395 from Pelican ... your price may vary
Chinese AA ... $400.00? |
type47 |
Feb 15 2012, 11:05 AM
96mm set from ... AA $386
http://www.autoatlanta.com/Porsche-96mm-Al...W9600T4B71.html Also check out Jakes offerings.... |
Cevan |
Feb 15 2012, 11:09 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
European Motor Works has Keith Black 96mm pistons for $45 each.
patrick3000 |
Feb 15 2012, 11:18 AM
Member Group: Members Posts: 192 Joined: 19-July 06 From: Maryland Member No.: 6,468 |
I paid $600.00 for the Euro Mahle set that went into the 912E that was a few years ago. Shop around and pay attention to where they are manufactured as Mahle has outsourced some of their manufacturing as of late. What else are you using in your build?
Best of luck. Regards, |
74porsche914 |
Feb 15 2012, 11:23 AM
I definitely cannot afford to pay retail but would like to get genuine mahle's. I planning to use LJet fuel injection, Euro Mahle pistons, and a Raby cam and valves. Anyone have Euro Mahle pistons for sale?
SUNAB914 |
Feb 15 2012, 12:44 PM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Euro Mahle pistons/cylinders $800.00+
I will be watching your build thread and parts list, thinking of doing samething later down the line. |
74porsche914 |
Feb 15 2012, 12:47 PM
Alright, glad your interested in the build. I'd love to start it soon but am at school and my 914 is back home. I may start some of the build in march when I go home for spring break, but the majority of it will most likely happen at the beginning of this summer.
904svo |
Feb 15 2012, 12:50 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Buy a set of 2056 piston and cylinders from Jake. In the long run you will
be suprise how much better your engine will run. |
Valy |
Feb 15 2012, 01:52 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I definitely cannot afford to pay retail but would like to get genuine mahle's. I planning to use LJet fuel injection, Euro Mahle pistons, and a Raby cam and valves. Anyone have Euro Mahle pistons for sale? How about cylinders and heads? Cheapest way is probably the way I went. See my rebuild progress (or lack of). I use AA 96mm pistons/cylinders. If you choose to reuse your cylinders and rebore them, there are many pistons options. Check summitracing for their offering around 96mm. You can narrow the search based on pin size and compression height. You'll need 1.45" and less for your motor without changing the rods. For cam I used Webcam #73 + 2.5deg on exhaust. This is the same one that Jake said he sells in his kit. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:17 PM |
