QUOTE(74porsche914 @ Feb 15 2012, 09:23 AM)
I definitely cannot afford to pay retail but would like to get genuine mahle's. I planning to use LJet fuel injection, Euro Mahle pistons, and a Raby cam and valves. Anyone have Euro Mahle pistons for sale?
How about cylinders and heads?
Cheapest way is probably the way I went. See my rebuild progress (or lack of).
I use AA 96mm pistons/cylinders. If you choose to reuse your cylinders and rebore them, there are many pistons options. Check summitracing for their offering around 96mm. You can narrow the search based on pin size and compression height. You'll need 1.45" and less for your motor without changing the rods.
For cam I used Webcam #73 + 2.5deg on exhaust. This is the same one that Jake said he sells in his kit.
