Loose oil filler neck, How bad, how to fix |
ripper911 |
Feb 15 2012, 12:04 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Posting from phone, neck and attachments are lifting up.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1329329051.1.jpg) |
tod914 |
Feb 15 2012, 12:20 PM
Have a gasket under it? Maybe double up on the gaskets or compress the bail abit more.
pilothyer |
Feb 15 2012, 12:30 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
If it is the gasket under the box that the bail holds down you can get the gasket without buying an entire engine rebuild kit.....it is part #021-115-487.....easily found at most VW places...if it is the o ring under the funnel it is part # 021-115-137 also readily available at VW places..............Another thing I am wondering what are you attaching that open PCV valve to, if anything?
pilothyer |
Feb 15 2012, 12:52 PM
Very easy fix once you get the parts.
Lo-Fi Version | Time is now: 17th May 2024 - 02:50 PM |
