ripper911
Feb 15 2012, 12:04 PM
Posting from phone, neck and attachments are lifting up.
tod914
Feb 15 2012, 12:20 PM
Have a gasket under it? Maybe double up on the gaskets or compress the bail abit more.
pilothyer
Feb 15 2012, 12:30 PM
If it is the gasket under the box that the bail holds down you can get the gasket without buying an entire engine rebuild kit.....it is part #021-115-487.....easily found at most VW places...if it is the o ring under the funnel it is part # 021-115-137 also readily available at VW places..............Another thing I am wondering what are you attaching that open PCV valve to, if anything?
pilothyer
Feb 15 2012, 12:52 PM
Very easy fix once you get the parts.
