two 1.7 motors |
two 1.7 motors |
the head |
Feb 20 2012, 12:19 PM
Newbie Group: Members Posts: 16 Joined: 8-October 09 From: des moines ia Member No.: 10,906 Region Association: None |
I have two 1.7 motors
First one Engine ran when we pulled it out last month. Includes Alternator, EMPI Mechanical Advance distributor with bosch red cap and bosch revlimit rotor with pertronix ignition module, new plug wires, air guides (except for alternator panel it was not on the motor when we got it), weltmeister oil pump high pressure upgrade, weltmeister deep oil sump, original taco plate with vdo temp sender installed, vdo oil pressure sender installed in stock location and bosch blue ignition coil. $100 or offer The second one swallowed a valve adjuster screw down the pushrod tube I will sell any parts off this motor or sell the whole thing for has original fi distributor and air guides as well. $50 Engines do not include clutch, flywheel or induction systems PM me for pictures, |
02loftsmoor |
Feb 22 2012, 09:28 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
any bites on the Engines??
I have two 1.7 motors First one Engine ran when we pulled it out last month. Includes Alternator, EMPI Mechanical Advance distributor with bosch red cap and bosch revlimit rotor with pertronix ignition module, new plug wires, air guides (except for alternator panel it was not on the motor when we got it), weltmeister oil pump high pressure upgrade, weltmeister deep oil sump, original taco plate with vdo temp sender installed, vdo oil pressure sender installed in stock location and bosch blue ignition coil. $100 or offer The second one swallowed a valve adjuster screw down the pushrod tube I will sell any parts off this motor or sell the whole thing for has original fi distributor and air guides as well. $50 Engines do not include clutch, flywheel or induction systems PM me for pictures, |
the head |
Feb 28 2012, 10:24 AM
rockers out of non running motor have sold.
Both have the 8mm adjuster screws in them. |
Lo-Fi Version | Time is now: 12th May 2024 - 09:56 PM |
