I have two 1.7 motors
First one Engine ran when we pulled it out last month. Includes Alternator, EMPI Mechanical Advance distributor with bosch red cap and bosch revlimit rotor with pertronix ignition module, new plug wires, air guides (except for alternator panel it was not on the motor when we got it), weltmeister oil pump high pressure upgrade, weltmeister deep oil sump, original taco plate with vdo temp sender installed, vdo oil pressure sender installed in stock location and bosch blue ignition coil. $100 or offer
The second one swallowed a valve adjuster screw down the pushrod tube I will sell any parts off this motor or sell the whole thing for has original fi distributor and air guides as well. $50
Engines do not include clutch, flywheel or induction systems
PM me for pictures,
