JoeSharpOld |
Does it seem cold to you ![]() ![]() Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 ![]() |
This started about 6 months ago as what I thought was as intermiten open in a loom. Its /L. car and I've replaced the Loom (Thank you Mr. Blowsby) all lines and hoses, intake manifold gaskets and boots, adjusted the valves, new injectors. What it is doing is fouling plugs at 3/2.
(IMG:style_emoticons/default/headbang.gif) Whats up wit dat (IMG:style_emoticons/default/unsure.gif) Joe |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
bummer joe! i hope it all sorts out (IMG:style_emoticons/default/unsure.gif)
JoeSharpOld |
I know that it will. What I'm thinking now is the CHT, haven't replaced that yet.
Thanks Aron, I'll see you at lunch. Joe |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Trigger points.. Must set gap. Oops never mind that would be 1-2 or 3-4. How about making sure the plug wires are connected nice and tight on both ends. Test with OHM meter. If you can't get low resistance pull off end cut 1/4" off and re terminate. Each end just screws into to conductor. If the connection is poor the electrical charge will jump across and "sort of fire". Real weak like.
Then you could be driving the injectors wide open and dumping tons of gas into those cylinders. Tough to test without a mess. |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Try to keep your wires the same length though, the tolerances of our injection units are so tight, that the length of wire being even .010 off can wreak havoc.
It can't really, I'm just trying to make you smile, as you walk to the chainsaw, and exact revenge on old space-age technology. (IMG:style_emoticons/default/welder.gif) (we have ignition) M |
JoeSharpOld |
Joe: After the GAF I'll check the pulg wires, but I have the wiers taped to the cap, cause I have an open engine bay, (GT lid) so that means I check the cap also (prolly a good idea anyway). Not likely to happen to 2/3 at the same time.
Miles: What can I say? Thanks for being YOU. (IMG:style_emoticons/default/biggrin.gif) Joe |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
rotor, cap, high tension cables, points first
dead plug(s) second cht third hari-cari fourth (IMG:style_emoticons/default/sawzall-smiley.gif) |
Aaron Cox |
sometimes your just like...
(IMG:http://www.flyingcirkus.com/forum/uploads/JohnVH/2004-07-16_075619_wtf_cat.jpg) |
JoeSharpOld |
SLITS: I'm at your third. Fourth is not an option.
Aron: YEP. (IMG:style_emoticons/default/confused24.gif) My resolve is tenacoius, I will adapt and conquer. (IMG:style_emoticons/default/smash.gif) Besides this is better than watching TV (IMG:style_emoticons/default/biggrin.gif) Joe |
phantom914 |
non-914-owner non-club member ![]() ![]() ![]() Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 ![]() ![]() |
Umm... how would the CHT cause anything different to happen to cylinders 2 and 3? (IMG:style_emoticons/default/huh.gif) Shouldn't the ECU lean or richen the same for all cylinders based on the CHT?
Andrew |
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
QUOTE(phantom914 @ Sep 10 2004, 09:05 PM) Umm... how would the CHT cause anything different to happen to cylinders 2 and 3? (IMG:style_emoticons/default/huh.gif) Shouldn't the ECU lean or richen the same for all cylinders based on the CHT? that's what i would think. i'd replace the FI trigger points, rotor, cap, plug wires, and double check all wiring. |
JoeSharpOld |
BTDT: Leaving for GAF now.
Thanks to every one. Joe |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
QUOTE(Joe Sharp @ Sep 10 2004, 05:05 PM) What it is doing is fouling plugs at 3/2. (IMG:style_emoticons/default/headbang.gif) Whats up wit dat (IMG:style_emoticons/default/unsure.gif) Joe Have you checked the injectors on the fouling cyls? Leaky injector = rich = fouled plugs? -Ben M. |
Lo-Fi Version | Time is now: 30th July 2025 - 10:28 AM |
