> bad... bad motor sounds, figures...
brant
post Sep 10 2004, 08:34 PM
anybody have any ideas of what I should suspect or inspect...
I started the car up to drive to work.. probably a bit cool and maybe 60 ambient.
drove easy for 10 blocks...
easily going down the street, maybe 30mph.. probably 3rd gear.
suddenly a bad metalic tic noise.
not speed dependant, but definitely rpm dependant
sounds exactly like an old tired chevy with a stuck hydrolic lifter on start up.
pretty loud...
tic.. tic... tic...
slows down when I push the clutch in and rpms drop.
I pull over and pop the old oil bath filter off.. sounds kinda like its coming from the center of the block (not the fan as I was hoping). noise is regular but slow at idle.
I shut the motor down and feel in the fan area, but don't feel anything bad (no lost screwdrivers)
drive home easy.
when I get to the drive way I push the clutch in and blip the throttle for the first time.
noise actually kinda goes away which doesn't make much since...
I grabbed the focus, and get to work late.
I won't be able to do anything until next week now, but I thought I would do another valve adjustment (200miles since the last one). Also thought I might cut the oil filter open, and feel the fan belt well in case it is splitting or something (not likely)
what do you guys think it is?
Its a tired 1.7 djet motor that I finally just got the FI working after 3 months of learning.
its only been runnin about 200 miles on it since may.. damn.. when it rains it pours.
(1st gear is gone, tranny is a piece of junk, and now I think I've blown the motor)
fixing this is serioulsy going to cut into my race car project if I touch it.. I might just park it until next year... damn....
what should I check for fellas?
brant
brant   bad... bad motor sounds   Sep 10 2004, 08:34 PM
redshift   Oh, ticking, idle on up.... 200 miles... adjust va...   Sep 10 2004, 08:40 PM
brant   I appreciate the encouragement.. your right... I...   Sep 10 2004, 08:43 PM
SirAndy   ...   Sep 10 2004, 08:43 PM
redshift   Sorry to edit on ya... I just realized there was ...   Sep 10 2004, 08:44 PM
redshift   <...   Sep 10 2004, 08:45 PM
brant   motor was cold, but not ice cold.. it was decently...   Sep 10 2004, 08:46 PM
redshift   I didn't mean to edit out the good thoughts......   Sep 10 2004, 08:48 PM
brant   your right... I'm going to have good thoughts ...   Sep 10 2004, 08:52 PM
- Lo-Fi Version Time is now: 2nd July 2025 - 01:55 PM
