| chris914 |
Sep 12 2004, 11:44 AM
Member ![]() ![]() Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Can the tailshift to side shift conversion be done with the engine in the car?
| MXMARK |
Sep 12 2004, 12:41 PM
Member ![]() ![]() Group: Members Posts: 205 Joined: 15-February 04 From: Riverside, Ca. the new (951) Member No.: 1,656 |
I think I pulled my motor when I did mine. You have to change the front motor mount bracket on the case, the rubber mounts, the cross bar and the outer mounts on the body. All of these where from the sideshift car. The shifter in the car and the linkage was swaped. [B]A new Bushing at the fire wall That fits the old hole and new smaller rod.
I Might have done it with the engine in the car but it was tough getting to the front engine mount bolts. Wow my memory is getting bad. I can't remeber if the engine was in or out. You will have to hold the engine up anyway. Sorry I was no help at all. Thanks Mark |
| lapuwali |
Sep 12 2004, 01:07 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
It's somewhat easier to wrestle the new gearbox onto the engine with the engine out, anyway. Lower it onto an appliance cart, swap the gearboxes and the mounting bars, and you get the opportunity to clean up the front of the engine bay, too. You could even do the easiest valve adjustment you'll ever do while you're there.
| MXMARK |
Sep 12 2004, 01:11 PM
You could swap your fuel line at the same time. Mark
| SirAndy |
Sep 12 2004, 01:30 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,563 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
can be done, but it's much easier (and faster) with the engine out.
you need to replace the engine mount bar anyways. the tranny is much easier to work with if the engine is out. make sure you get all brand new bushings for your new shift linkage, including the *correct* adapter bushing for the firewall. make sure the new linkage is not worn or bend before install, there should be no twisty play in the couplers. you can do it in one saturday. oh, btw. it's *much* easier if you have another set of hands. get a friend who knows a bit about working on cars to help you out ... (IMG:style_emoticons/default/smash.gif) Andy |
| jr91472 |
Sep 12 2004, 03:43 PM
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Chris,
I am doing that very thing right now. Just finished installing new tranny with engine still in the car. Next I was able to fairly easily remove the cross member and inboard mount brackets. But as stated previously, this is when you wish the engine was out. Tomarrow I will work in installing the new inboard brackets and new cross member. I can tell you for sure that I will not be able to get a torque wrench on the two upper bolts for the bracket. Medium length rachet - yes, longer torque wrench - no If possible, I would remove the engine as it will clearly be easier. But to answer your question, yes it is possible. If interested, I can provide more details/hints I found along the way. |
Lo-Fi Version | Time is now: 24th November 2026 - 12:52 PM |
