Vacuum leak found!, carb cleaner technique, |
Porschef |
Feb 26 2012, 01:34 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Ive been looking for this one... feeling like there was still a vacuum leak somewhere.
Found it at the throttle body gasket... I'm gonna try to reinstall this one, dont know if it will work..it doesn't look terrible but apparently it leaks... Pelican shows it as NLA. Does anyone know a source? Thanks, Joe |
JawjaPorsche |
Feb 26 2012, 02:39 PM
914Rubber sells one. I don't know if this is the one you need:
http://shop.914rubber.com/product.sc?produ...p;categoryId=11 Terry Ive been looking for this one... feeling like there was still a vacuum leak somewhere. Found it at the throttle body gasket... I'm gonna try to reinstall this one, dont know if it will work..it doesn't look terrible but apparently it leaks... Pelican shows it as NLA. Does anyone know a source? Thanks, Joe |
jonferns |
Feb 26 2012, 02:43 PM
Porschef |
Feb 26 2012, 03:07 PM
Hey Jon, just sent you a pm. That looks like it, BTW. |
Porschef |
Feb 26 2012, 03:15 PM
Update,
I cleaned up and reinstalled the gasket. Idle jumped up 300+ rpm. Also smoothed out. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) I'll call this good for now, but will get a new one. Also noticed when spraying some cleaner right on the idle adjustment screw, it bumps up slightly. Gonna try a wrap of Teflon there... Joe |
tod914 |
Feb 26 2012, 06:13 PM
The screw is designed to force an airleak. Don't think you want to tape that.
Porschef |
Feb 26 2012, 07:25 PM
I'm saying that it seemed that the screw itself was allowing air through... But I agree, with the very fine threads it would seem that that wouldn't allow air through. However, I wrapped a very thin strip just at the top of the screw, and, no idle speed change with the carb cleaner spray.
So overall it was a success. Engine is now smoother than ever at idle. Tomorrow, after she cools completely, I'll start her and see how it is. Gotta love eliminating a bug, no matter how small.... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:53 AM |
