F/S! Nice, unbroken, all fins intact, engine cooling fan!, Early version, but it'll fit a late car with the correct bolts. |
Cap'n Krusty |
Feb 28 2012, 07:39 PM
OK, you win, I'll drop the price! 55 bucks apiece, you pay the freight! No broken fins, no cracks, no no. I'll make sure yours is marked for your particular engine.
The Cap'n |
914ltd |
Feb 29 2012, 07:16 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Cap'n Great price! Possibly a majority of these have broken fins from using a pry bar to turn the engine. Another balance issue is if they have been disassembled to paint. Brad Mayeur
euro911 |
Feb 29 2012, 08:52 PM
... Another balance issue is if they have been disassembled to paint. Brad Mayeur I pulled that stunt - once (IMG:style_emoticons/default/dry.gif) ... I couldn't believe all the holes the balance shop had to drill into the back side (IMG:style_emoticons/default/blink.gif) |
ThePaintedMan |
Feb 29 2012, 10:44 PM
Yikes! We're not supposed to paint them? Uh oh... What if it was never disassembled but just shot with rustoleum?
euro911 |
Mar 1 2012, 10:50 AM
It's OK to paint them. The balance problem comes into play when they're disassembled (to bead blast, etc). The pulley and fan units are balanced as a unit and if taken apart, everything must be put back together in the same exact position.
Nie Zu Alt |
Mar 12 2012, 03:36 PM
Member Group: Members Posts: 173 Joined: 1-June 05 From: Centennial, CO Member No.: 4,184 Region Association: Rocky Mountains |
PM Sent
Cap'n Krusty |
Nov 20 2012, 06:18 PM
OK. It's nearly the end of the year, and I need this thing to go away. I can't believe nobody here needs a good, unbroken, engine fan. Help me get the barn cleaned out!
The Cap'n |
Cap'n Krusty |
Apr 30 2013, 01:24 PM
Sold, paid for, and shipped! Thanks! The Cap'n
Cap'n Krusty |
Jul 17 2014, 12:54 PM
Came across another one! It's early, takes the triple square bolts. Dirty but intact. $55 and shipping. I DO NOT have the bolts!
tweet |
Jul 17 2014, 08:09 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
It's OK to paint them. The balance problem comes into play when they're disassembled (to bead blast, etc). The pulley and fan units are balanced as a unit and if taken apart, everything must be put back together in the same exact position. How can they be re-balanced? Is there anyone that does this work. Should they be painted and then re-balanced? I have one that is off the engine, but still assembled and another that is apart. |
bdstone914 |
Jul 17 2014, 08:16 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
It's OK to paint them. The balance problem comes into play when they're disassembled (to bead blast, etc). The pulley and fan units are balanced as a unit and if taken apart, everything must be put back together in the same exact position. How can they be re-balanced? Is there anyone that does this work. Should they be painted and then re-balanced? I have one that is off the engine, but still assembled and another that is apart. Try contacting a local engine rebuilder. It is a rotating part just like a flywheel or clutch. The factory manual might say how close they were balanced. Most of the engine components had loose specs for balancing and variation. I have to wonder how much balancing affects them having seen fans with thick dirt build up on the fins. |
tweet |
Jul 17 2014, 08:22 PM
Thanks Bruce. When I originally took it apart, that was my initial thought. The fan I took apart had melted plastic, oxidation and rust. So I figured it just would never work correctly like that. I needed to separate the parts to clean it up. I just always assumed there would be shops that can balance them again. I don't know about shops that drill holes in them though. I guess when the time comes, I'll have to choose carefully and ask a lot of questions.
JStroud |
Jul 17 2014, 11:44 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Any good machine shop should be able to balance a fan.
Cap'n Krusty |
Oct 2 2014, 12:48 PM
ONE left!
The Cap'n |
Lo-Fi Version | Time is now: 29th May 2024 - 12:01 AM |
